gary_yuen42
#1 ◈ 2016-04-02
Trying to play with datalog today however it throws a Run Time Error '6' Overflow. I didn't start the car, just in ignition position without engine on. I have set the baud rate in TE (2.6.1) to 38400 and also in the device manager under control panel in window I have set the bit per second to 38400 with latency to 1.
So I press connect the start datalogg in most cases it will come up Run time Error '6' over flow..... Some times the table window will be running as if it is logging ... all value display 0.... even I press the throttle the TPS should still have a value even when engine off. Then after a wee bit longer / when I click on something else under the dataloggin in TE, it will throw the same error...
Any one got any idea about this?
