Dmc1 wrote:
How would I tune the ignition close enough without a dyno?
The best way to find optimal timing for the street and track, is to tune timing at the track. I personally don't like car dynos, simply for that fact that, the optimal timing and a/f on the dyno is not ideal for the street, because the load is just a simulation.
If you throw parts together, then you would need a car dyno to make up for the mess and all the tq dips, but if your engine combo is rpm based and tuned length is calculated, then you'll know where the engine will need more or less timing, as well as what rpm the most fuel will be burned. Depending what combo you have, the peak tq and peak hp will be either at different rpms, or in the same rpm range. Header theory plays the biggest role with this.
Start with the timing maps on the conservative side, but based on your dynamic compression. Push 1 degree more timing where peak tq is and 1 less degree timing where the peak hp range is. Example, 23 degrees from 5500-6500 and then 22 degrees from 6500-7500. If you tune the a/f ratios to be even across, run that at the track. Then you make several other bin files with ONLY TIMING CHANGES in the Hi cam map. One bin will have +1 degree timing, where another bin will have -1 degree timing. As far as the low cam, i keep the timing semi conservative and tune the a/f ratios first of course to achieve targeted lambda.
If you keep tire pressure, launch rpm, and shift points the same, (obviously there are more variables which are endless), you can compare your 1/8 mile time and the second 1/8th mile time, which you get by subtracting the 1/8th mile time from your 1/4 mile time. Also compare trap speeds. No need to really rush, trial and error and patience is key. When you see what timing yields the quickest time with the most speed, then you can go with that timing map, simple as that.
Then next track session, advance your intake cam 1 degree, set the dizzy, then set the a/f ratios to be the same across again, where needed. Run that at the track, and you can play with +1 or -1 timing across. Then the week after you would advance the intake cam another degree, and so on. Give yourself data to compare, and in the real world, you'll see what works, and using your INSTINCT will get better as you keep practicing test and tuning. This is the way i do it, and it works.
It really boggles my mind when i see peeps do a swap, then they need the car dyno for tuning, and they are stuck at the track with no tuning adjustments for a whole season, and they plateau. Just giving my 2 cents.
