sakpase
#1 โ 2019-11-13
I'm using the latest of TE with ECUcontrol plugin, I'm getting data but I'm not logging. Should there be blocks filing up with information? I just have numbers changing like; RPM, TPS, and MPH to name a few the O2 info fluctuates also but I"m not sure I'm receiving good info.
It took a lot of work to get the DKU-5 working but it is now.
I"m using a Zeitronix analog output to a PM6 ECU at the O2 connection on the engine block.
I notice people speak of seeing ratio's like 14.7 or 13.5 with accelaration but I don't see anything like that,
I would like a little help on this one. I would like to use maptrace(I've heard it makes tuning a little easier along with autotune)
Basically.....I am getting the information how do I log it? I'm sure I can manipulate numbers (in small increments) but I just need to log though
any help would be appreciated.
