PM7 Rev Limit
grevis
#1 ◈ 2024-11-11
I am a newbie who tried to find the rev limit for a PM7 in the forum and wiki but did not see it (probably should have looked through again).
Had a play with my PM7-000 ecu ROM and found the rev limit is at address 0EB2h (using the 16bit OBD0 formula)
Great website guys, keep up the good work!
sk8bdr15
#2 ◈ 2024-11-11
7200rpm and speed limiter 112mph
ZCRXO
#3 ◈ 2024-11-11
grevis,
i have the same ECU and i tried for long searching for information for the ECu i have but it seems no one knows about it
can you please share some of your information with me
what kind of engine u r running? i have a ZC
do you have a pinout diagram of the ECU
what kind of data logging u r running-software- i used ECUcontrol but i got all data missed up
what data cable u r using for data loging, i'm using DKU5 from nokia
one more qu?
what is NG55 and NG60? and is it posible to do data logging with a standard ECU
grevis
#4 ◈ 2024-11-11
Hi,
I was just using winhex to find where the revlimit was in my PM7 ecu. I tried using turboedit to alter the maps, which did work, but did not have a go at datalogging and editing online.
I did not do too much more with the PM7 as I have changed to a B20 vtec engine and PW0-000 computer that I took to the dyno shop and tuned using Ben Ogles rom editor and ostrich from craig moates (which work exceptionally well).
The NG55/NG60 roms are not ones I have played with. I think they are for the PM6/PM7 ecu's and have been modified to give extra tables for boost pressures on the MAP sensor. I think that Ben Ogles editor (BRE) supports them so if you are doing a turbo setup, try that.
Grevis
