really want to learn
nam
#1 ◈ 2012-02-02
I have been running crome for 8 months now and i am really interested in learning to tune my car myself so I joined the forum to learn some more before i start messing around
Turbo&Auto
#2 ◈ 2012-02-02
Theres a seminar in Vegas coming up in the beginning of November :) Otherwise, I would read in the Wiki. It would be a long post if I tried to tell you how to tune your car :)
nam
#3 ◈ 2012-02-02
The first thing is that I live in jamaica so I have to get all my info from the net :cry: . I have an aem uego, do I still have to buy an Innovate if I go crome pro or can the aem wideband work
Turbo&Auto
#4 ◈ 2012-02-02
The AEM will work.
Crash course in tuning, very basic info.
If you have a turbo car: tune the fuel map to hold 12:1 anytime in boost. Log your Wideband on WOT passes and adjust the fuel map to hold a stable 12:1 all the way to redline. Then do the same with part throttle except 14.7 is the target A/F. I like to make it 12.5-13:1 from 10" of vacuum to 0.
If its a NA car, tune WOT to 13:1 or a lil leaner if you want. Then 13.5:1 for 10" of vacuum to about 2" of vacuum.
Timing is a whole other thing. There's way too much to it. Try to use a base map for your car and load boost tools. Make the retard .75/psi of boost for starters. Then do some WOT passes and watch your EGT. If it climbs fast up to 1500+, change the retard to .5/psi of boost. Do another WOT pass, if its still too hot try .4 and then .3. Monitoring a knock sensor is a good idea, specially if you get into the .4 or .3 area. Could be possible that if you get all the way to .25/psi of boost that your base map is shit.
Good luck :)
nam
#5 ◈ 2012-02-02
Thanks for the info. really appreciate it
Turbo&Auto
#6 ◈ 2012-02-02
Make sure you buy a EGT man, rly worth every penny. If you see it climbing into the 1600 range at any time, LET OFF THE GAS!!! Be observant when you tune and take your time, I'm no pro but my cars run A+++++++
