IntegraKarim
#1 ◈ 2012-02-10
Well heres my story of I think us finally tuning right.. maybe?
First fixed my idle using this thread:
viewtopic.php?t=8651&highlight=
Actually used raene's advice of just changing the timing, i think adding some more idle room might still be necessary or just changing surround timing cells to the same as the others. (If you read Raene's post youll understand)
Went around doing some full throttle boost tuning. Got AFR's from 10 AFR to about 12's so I think thats better.
Its kinda difficult, we do a low third gear pull, my friend drives and i watch where the tracer goes, I follow it and lower the fuel (because it was running too rich 10 AFR's ,remember? thats rich, i go more lean)
So once I got in the 12's we did timing.
For timing I did the same thing, for both fuel and timing when youre fuel throttle you dont really see it jump around much, only around a certain number of cells that it does everytime, is that right?
Anyway I went in the options and got to a point of .37 degree retard per lb of boost. No pinging, spark plugs look fine.
I wasnt sure because im really not sure how much im suppose to advance the timing. Anyone wanna give me more info on this part?
Well all in all I like how the car runs, a lot smoother but still I think it could have a lot more power, at least my butt wasnt feeling it.
Any advice? Your tuning methods/ stories?
