Getting a Baseline
Before changing things on my car, I wanted to get a good picture of how things were currently running so I would have something to compare it to later. My car had been running fine for a couple of years, so I wanted to take a snapshot of things in case I ran into problems later. Having a baseline and only changing things one at a time would allow me to diagnose problems more quickly and revert to a working configuration.
I already have a DIY electronic gauge with boost and fuel pressure. The values are displayed to an LCD, but more importantly readings can be logged to a PC. Although these data points are somewhat interesting, a much more important metric on a car's tune is the AFR (air-fuel ratio). I purchased an LC1 from Innovate Motorsports because it is relatively inexpensive and got good reviews on different sites I checked. The Innovate Motorsports website can be found at
http://innovatemotorsports.com/.
Innovate also has a forum for help with their products, so be sure to use that if you get in a jam. There appears to be quite a number of people who have had issues with early LC1s, although it seems as though Innovate has worked those things out for the most part. Handle your wbo2 with care! They are somewhat fragile. It seems that the LC1 is more immune to noise than the LM1 due to the separate analog grounds.
Wide vs. Narrow Band
If you don't understand the difference between nbo2 and wbo2 sensors, you should do some reading. Here's a link to give you a high-level overview
http://auto.howstuffworks.com/question257.htm. In short, an nbo2 can really only sense lean or rich conditions; its output is highly non-linear and typically changes from 0 - 1 volt. A wbo2 and associated controller typically outputs a signal from 0 - 5 volts and can accurately read and represent AFR values from .5 to 1.5 lambda. An nbo2 cannot be reliably used for tuning, but a wbo2 can. Your Honda ECU only understands nbo2 signals, though.
O2 Sensor Installation
The Innovate Motorsports website contains documentation and even some video on the LC1 and associated software. Check
/pgmfi/forum/media/a3/a3376fb36dd323f9db9a61a6ae437db0685a6c7e4043a612c3e9056746108d4e.pdf for details on the sensor wiring, mounting location, and a lot of other good information. I've seen lots of posts on this forum asking how to hook up the LC1. RTFM (read the fine manuals) and you will find what you're looking for.
I mounted my wbo2 (wide-band o2 sensor) in front of the CAT, which is probably close to 3' from the turbo outlet on my car. I was able to mount my wbo2 so that it points straight up, which is the recommended orientation. It should not be mounted below the 3 or 9 oclock positions and should *not* be placed close to the turbo since the heat from the exhaust could damage it there. Placing any o2 sensor too close to a turbo outlet can also cause inaccurate readings due to turbulence and pressure in that location.
When I initially installed my turbo kit, I was told to put the stock nbo2 (narrow-band O2 sensor) just ahead of the CAT. I thought it might be better closer to the turbo, but did what I was told anyhow. I decided while I was moving and welding things up, I would relocate my nbo2 closer to the turbo since an nbo2 needs to run a little hotter than a wbo2 and I think my closed loop operation is smoother with it there. I used to log AFR readings from my nbo2 with my DIY gauges and noticed that the AFR swung more widely with the nbo2 further down the exhaust. I ended up relocating it about 10" after the turbo in the bend of my DP (downpipe). The stock configuration for my car is to have the nbo2 sensor in the exhaust manifold, not far from the exhaust ports so I'm sure it can handle some heat.
It might be worth mentioning that the LC1 comes with a bung and threaded plug for said bung. I used it for the wbo2 sensor that comes with the kit. Since I chopped my previous bung up removing it from the old location, I had to purchase another bung for my nbo2. I checked NAPA, Autozone, and a few other places, but found that an exhaust shop was the only place that had one on hand. The standard price seems to be $10.00 here. I used a 110V MIG welder with gas to weld things up. I have two o2 bungs in my exhaust so I can use both types of sensors simultaneously, which can be very handy.
Make sure you don't have any exhaust leaks! Leaks will affect your AFR readings and will create a lean reading or lean spikes. An exhaust leak will *not* register as a rich value, which seems more intuitive to most people at first. While I was re-drilling a hole in my exhaust manifold for an EGT (Exhaust Gas Temperature) sensor I noticed that the readings did indeed get leaner until the hole was plugged.
The Innovate Motorsports website has lots of good information about tuning and tuning theory. I read everything I could find there. The link is found above.
Wiring
You can find other posts with details on LC1 wiring from
http://www.innovatemotorsports.com/forums/showthread.php?t=3410,
http://forum.pgmfi.org/viewtopic.php?t=9645&highlight=. The link also points to a document found
http://www.m2motorsports.com/files/lc-1_write_up.pdf that is pretty good. Also,
http://forum.pgmfi.org/viewtopic.php?p=63467&highlight=lc1#63467 will give you an excellent explanation of how to connect things.
I wanted to mount my LC1 semi-permanently, so decided to add connectors to the end of the LC1 cables. I used a polarized two-position connector for the red and blue wires and a mini-DIN connector for the others. This allows me to move my LC1 to different vehicles and also connect it in different configurations in my Civic for different tuning needs.
Initially when I was obtaining baseline data, I just connected my LC1 to my laptop and used the Logworks software. I later connected it to my ECU and logged things through Crome Pro (the free version does not support logging), but I'll get to that later. Having the connectors allows me the freedom to do those kinds of things without messy rewiring. I obtained the two position power connector from Autozone and the mini-DIN male and female connectors from
http://www.digikey.com. The part numbers are listed below. I also put an inline fuse in the LC1 heater circuit for an added measure of safety. The Innovate docs say to use a 5A fuse at minimum.
My initial wiring for the LC1 consisted of two small wiring harnesses. The first wiring harness was for main power and the heater ground, which are the red and thick blue wires respectively. I call this the main power harness. The second wiring harness connects the white, yellow, brown, green, and black wires to a Mini-DIN connector so they can be attached to different places. I call this the data harness.
To make the main power harness, I connected a black wire to the two position connector and then grounded it under a bolt that holds the ECU bracket to the inside of the car. The other wire from the two position connector is routed through a fuse holder to the cigarette lighter wire, which is a switched 12V source.
The data harness was created by soldering a Mini-DIN plug to the LC1 wires. I color coordinated the wires on the plug so they would come out on the same colors when the receptacle was connected for the most part. I then soldered a Mini-DIN receptacle into the car. The white, and green wires from the LC1 connect through the Mini-DIN connectors to a wire that is grounded under another bolt that holds the ECU bracket to the car. The black wire connects to the red wire of the LED and one side of the push-button switch that comes with the LC1 kit. The black wire of the LED connects to the white and green wires, which are ground. The remaining wire from the push-button switch is also connected to ground (white and green wires). I left the yellow and brown wires unconnected in this harness. I use them in a different version of the data harness later for a connection to the ECU.
Main Power Harness
LC1 Connector Car
Red Red - White Fuse holder -> Cigarette lighter
Blue White - Red Chassis ground (bolt on ECU bracket) ** see caveat below
Data HarnessCode:
LC1 Mini-DIN (plug-receptacle) Car
white white - blue Chassis ground (another bolt on ECU bracket) ** see caveat below
yellow yellow - yellow NC (no connect)
brown brown - brown NC
green green - green Chassis ground (with white wire) ** see caveat below
black black - black LED red wire, switch wire 1
Note: Also connect the LED black wire and switch wire 2 to the blue and green wires on the Mini-DIN receptacle.
Note2: Also note that the Mini-DIN receptacle doesn't have a white wire, so I used blue to mate up with the white wire from the LC1. Don't get this confused with the blue wire on the LC1, which is the heater ground wire.
Caveat: Connecting the LC1 to chassis ground is *not* recommended if you're going to connect the analog outputs to your ECU. See a later post about that below.
Digikey Part Numbers
Mini-DIN receptacle - 275-1105-ND
Mini-DIN plug - CP-2080-ND
Replacement O2 Sensors
One of the links above will list this info, but replacement wbo2 sensors are available for about $40, which is cheaper than the nbo2 sensors I have been buying for my car. Not bad. I've taken the liberty to cut-n-paste part of the text here.
Quote:
i got mine from 1stVWParts.com for
Subtotal: $38.29
Shipping: $7.95
Tax: $3.37
LogWorks Software
I think it's worth mentioning that the Logworks software provides a great datalogging interface compared to Crome Pro, for example. The only way to get graphs from Crome Pro datalogging is to export the data as a CSV and import it into another program (like Excel). Logworks has run-time graphs that can be manipulated and zoomed, etc. I like the software so much I may build a bridging device to convert my ECU output to a format that the Logworks software can understand. Innovate sent me details on their protocol. I'll let you know if I manage to build something.
Summary
I used the wbo2, EGT sensor, fuel pressure, and boost gauge to take a picture of how my car was functioning before starting to change everything. I would have liked to tap into the ECU to obtain readings from the myriad of sensors already on my car, but datalogging from the ECU cannot be done with the stock ECU configuration and Crome Pro. Other steps must be completed before that data would be available. Read on if you wish to find out how.
