Street Tuning
Disclaimer: Street Tuning is dangerous. You can hurt your motor, run into another vehicle, run your car off the road, and many other potential problems. There are a lot of things to keep track of to prevent disaster from resulting. You must keep track of RPM, MAP, AFR, watch the road, listen to the engine, etc. Please be careful! Also, I'm not a professional tuner so follow my recipe at your own risk.
Base Tune
Successful Street Tuning starts with a good base tune. A base tune is a binary you load into your ECU that will control the engine close to its required specifications.
You can acquire your base tune via a number of means. You might download one from the PGMFI Wiki, get one from [/url]http://xenocron.com/[/url], use a friend's bin file, or get one from a good tuner just as examples. You'll want to get your map from a trusted source since a bad base tune can make your life miserable at best and ruin your engine at worst.
Your base tune should match the specifications of your setup as closely as possible. You should try matching engine displacement, compression ratio, cam profile, injector size, fuel pressure, turbo setup, exhaust, and any other variable you can think of. Some of the more significant things to match are displacement, injector size, and engine type. Even an change in internals with the same block will change engine type.
You might be able to find a base tune that fits your setup very closely, or you might not. The closer you can get your base tune to your specifications, the easier, faster and safer you will be able to tune your car.
IMPORTANT: Any bin file you get from someone else should be considered a base tune unless you are running a bone stock setup with an original bin file. There are so many variables that change from setup to setup. You should verify your car runs good on any bin file before you use it permanently with complete confidence. Using a bin file that you *think* should be okay for even a short time without at least checking AFRs can easily result in a burnt down motor.
Most of the tuning guides I have seen on this site assume a good base tune. The process for tuning an engine with a base tune that is very different from the target setup is much more involved and requires more experience than newbie’s have. It’s something the tuner has to work up to by tuning cars with pretty good base tunes first.
If you read the first part of this thread you know that I used a stock P28 bin file to start with and then changed the fuel map for bigger injectors, added columns in the table for boost, etc., etc. Although compensating for larger injectors seemed simple to me, it might have been nice in retrospect to have something that already took my turbo into consideration. The aspect of my base tune that has required the most work is the change in timing I’ve had to make in the lower sections of my maps to compensate for the turbo.
Tips
Before we get too far, I'd like to list a few tips that I have picked up along the way. Some are from members of this forum, some are strictly my opinion, some may be wrong, ... you get the idea. If you follow these tips in addition to good common sense, you will hopefully be able to safely figure out the rest given enough time and experience.
* Have the best base tune you can find before you start tuning.
* Know how things work before you change anything in your bin file.
* Have a good baseline of measurement so you know how things are *supposed* to work if possible.
* Make only small adjustments at any one time.
* Only change one thing at a time.
* Have as much instrumentation as you can so you can measure what's going on. You can’t improve what you can’t measure.
* Have accurate instrumentation.
* Make your maps smooth.
* Find a good place to tune.
Making Small Adjustments
Making small adjustments will help reduce risk as you tune. You might feel that you are progressing at snail pace by making small adjustments. If so, you're doing it right!
Check all your instrumentation carefully after making adjustments to ensure that the changes you've made have improved things and not hurt them. You should already know how your change *should* affect the engine before you make it. If the change doesn't affect things the way you thought, revert your change and think things over again. Figure out why it didn't work the way you thought! The motor is *never* wrong when it starts to ping or run poorly - it's always you.
Once you get a concrete feel for how changing something affects the myriad of engine vitals and by how much, you can start changing things quicker. Obviously your tune time will decrease and you will become faster with experience. Always error on the side of small adjustments when you get into new territory or things aren't working the way you think they should.
Only Change One Thing at a Time
An engine is a very complicated collection of electrical, chemical, mechanical, thermal, pneumatic, and hydraulic systems (I'm sure I missed something in there
). There is a lot of complexity in an engine. Managing that complexity is the key to successfully tuning your car.
You may feel that things are going too slow if you only change one thing at a time. Changing one thing at a time will seem slower in the short term, but will often result in a much faster tune in the long run. It will certainly be safer.
Changing multiple things at once will often leave you guessing as to what caused a change in the engine's performance. Sometimes the two things you change will cancel each other out and seem as though they were ineffective, even if they were significant. The worst case scenario would be that changing multiple things at once causes a dramatic effect which results in a failure or permanent damage. Most commonly, changing multiple variables at one time causes confusion which results in lost time while ignorantly pursuing a lost cause. Add these detours up and you can see why it often takes longer to complete the entire tune even though it may seem slower in the short term when you only change one thing at a time.
As you gain experience and obtain a concrete understanding of how changes affect the engine, you can change more than one thing at a time. You will still have to gauge the risk of each variable you are changing. It will probably never make sense to change some things in combination. Erring on the side of changing one thing at a time will keep you safer and quicker in the long run.
Instrumentation
Having good instrumentation is crucial to safe and effective tuning. You *must* have a wide band o2 to safely and accurately tune. You might find a source or two on the Internet stating you can do it with an nbo2. Don't follow that advice! You're on your own either way.
You should be able to view and log RPM, MAP, and AFR *together* at a bare minimum. Without sampling them at the same time, each piece of data is not worth much. Having them together gives you the context you need to understand how the engine is performing. This means that tuning by watching you wbo2 separately from your tach and boost gauge is not advised. You can do things this way, but it will be riskier, take longer, and be less accurate. It's a recipe for disaster on the road while Street Tuning.
Another instrument that I highly recommend is a knock detection device of some sort. The home made det can in the Toys and Tools section of this site works well for me. It took me a while to tune my ear and brain to what detonation on this engine sounds like, but I trust it more now than an electronic device. Since detonation sounds so different for each engine, it’s difficult to build an electronic device that is properly tuned for every setup. By using a low tech, low budget det can you can save a few dollars and leverage the power of your brain, which is a powerful and adaptive device. Knock can be very difficult to hear without the aid of a det can.
Using your eyes to read plugs can be helpful. Plug reading is somewhat of an art and can be difficult if you're color blind, like me. There are some tell tale signs of problems like black peppering and balls of aluminum that should be avoided. I once had detonation so bad that the insulator on the tip of the spark plugs cracked! Something like that is an indication of severe detonation. Hopefully you never experience it. Only split seconds of detonation that severe will do fatal damage to your engine. I got lucky to only have lost a head gasket.
I have found TPS and tach data to be helpful at times. Vehicle speed might be interesting if you have a lot of wheel spin problems. Speedometer info can also be used in combination with RPM to determine gear. ECT (Engine Coolant Temp) and IAT (Intake Air Temperature) can be nice, too, but I haven't found them to be very critical except for long term trending.
Logging is important because it allows you to carefully view things after your run in safety because you don't have to worry about keeping the car on the road while you analyze the data. Keep your logs in an organized manner so you can refer back to them later when you have questions about how your motor is running. Comparing results you think may have changed to your old logs can be very helpful when trying to track problems down. I name files by date and even keep a small text file with information about each of them.
Accurate instruments are important. Bad data is sometimes worse than no data at all. Does spending $50 or $100 less on a wbo2 make sense if its inaccuracy causes you to burn your motor down? That $100 is going to look pretty cheap when you have to pay for a new engine. You often get what you pay for. Don't short-change yourself in the area of instrumentation; it’s important.
Make Your Maps Smooth
This tip is somewhat subjective. I'm not talking about turning your maps into a perfectly linear slope. Good maps often won't even come close to linear. Making your maps smooth means they shouldn't have sharp transitions in opposing directions or contain individual cells that are dramatically different than neighboring cells. You can use a good base tune’s shape as a guide for your new tune if enough of the engine specifications are the same.
If you watch things in nature they rarely behave in sharp transitional ways. For example, when you increase the pressure of water in a garden hose, it doesn't shoot out of the end of the hose a short distance for a while and then all of a sudden increase three-fold. Instead, it shoots out of the hose an increasing distance in proportion to the increase in pressure. The rate at which pressure and distance relate may change, but even that is in a relatively smooth fashion.
Your engine is just one big collection of natural forces and interactions. As you make changes to fuel and timing maps, make small adjustments and ensure that they transition relatively smoothly with surrounding cells. Since the ECU is almost always reading data from multiple cells at once, you will make your life more difficult if you make large changes from cell to cell because understanding how much weight the ECU is placing on your change is very difficult to estimate in real-time.
Find a Good Place to Tune
Finding a good place to tune can make your job safer and easier. I'm lucky in that I have a highway very close that I can hop on and off easily. I have created a route of mostly right turns so I don't have to wait for traffic lights a lot. Your route should be quick, easy, and as safe as possible. Including areas in your route that allow you to safely pull over and inspect data and make adjustments is nice, too.
Although surface streets can work okay for low RPM tuning, they aren't a good place to conduct WOT runs. They're often bumpy, narrow, have too many cars, and too many pedestrians. The low speed limit is very limiting, too. Shooting past the speed limit, while watching a bunch of gauges, is a sure way to put yourself and others in grave danger. There are reasons for speed limits. The cost of your tune can never be measured if you seriously injure someone while making it.
Pick a spot with low traffic and good visibility. Gradual hills can be useful to help load your engine as you tune, but make sure you can see what's ahead of you without too much trouble. Picking a good time of day can change these factors, too. I often tune late at night because traffic is low and pedestrians are scarce. The air is also cooler, which I like, and no one can see the ear protection det can I'm wearing. The downside to tuning at night is that visibility is poor.
A lonely country road might be a good place to tune. Just be sure that you have a plan in case your car won’t get you home after your tuning session is over.
Another helpful thing to do is to take a friend who knows a little about cars with you to drive while you tune. Be sure they know when to get off the gas and can follow your directions well. Then have them drive to your specification while you focus on the data and tuning. The result is more concentration on the road by the driver and more concentration on the data by the tuner simultaneously instead of trying to multitask by doing it all alone.
More Tuning
These tips will help you get started. I plan add a couple of example tuning sessions next that should spell out more detail. It’s not a complete guide by any means. I’ve still got lots to learn and my car’s tune is not complete.
Most of this stuff is common sense and a summary of the things that you can find in many different places on this site. Hopefully it will help newbies get the big picture sooner.
