SephirXV
#1 ◈ 2012-09-19
I'm building a P75 to run an 89 Accord LXi. In searching for how to operate my IABs, I also ran into the all out p75->p72 conversion, which would give me VTEC/knock connections, and decided that those would be nice to use for use for I/O for later projects.
In looking into the actual electrical connections, I've learned that the VTEC solenoid is a simple 12V when on, and the ECU checks for 14-30 ohms to dectect whether it is connected.
I know there is a VTEC switch/pressure sensor, but am curious as to what are the electrical characteristics for the ECU circuit it is connected to. Does it just detect on/off, does it actually read a pressure, and if so, what voltage range/resolution can it measure?
I know that the knock sensors have an interface board that connects to the ECU via a connector, I was wondering what those connectors are wired into the ECU side of the connection? If I have to, I guess I can trace the leads, but without a clue as to what is on the knock board side of the connection, I might not be able to fully understand them.
Ideally, I will have enough outputs to operate a mux and then have access to a bunch of inputs.
Anybody who could point me in the right direction would be appreciated.
