ROM BURNER
shanevas2
#1 ◈ 2025-02-14
Ok I am looking for the burner for crome. Can some one please help me. I am seeing some of these but they are way diff then the one i use to tune Mitsubishi.
civic_r87111
#2 ◈ 2025-02-14
You are just talking about a chip burner right? If so you have several options (Moates burn1, willems, tops, ect.) that can be used. If you already have a chip programmer it should work as well.
shanevas2
#3 ◈ 2025-02-14
Well have crome, which one would you recommend??
Equilibrium
#4 ◈ 2025-02-14
Insturctions
http://www.moates.net
Checkout chip programmers
Purchase Burn1 and 4 extra ROMS
shanevas2
#5 ◈ 2025-02-14
you have to remove the chip each time you retune it though right?
civic_r87111
#6 ◈ 2025-02-14
Yes, if you are not using the Ostrich.
loserpunk
#7 ◈ 2025-02-14
i would get the burn1..pretty user friendly. think about gettin the ostrich too because it makes tuning so much easier
shanevas2
#8 ◈ 2025-02-14
You can plug up the ostrich while you are tuning it so you do not have to keep taking the chip in and out right? it will just run off of that?
civic_r87111
#9 ◈ 2025-02-14
Yes, that's exactly how it will work
ezyride
#10 ◈ 2025-02-14
do u have to modify the car ECU (add a chip) to tune or change rom settings using ostrich
ncz31
#11 ◈ 2025-02-14
You have to add a socket for the chips/emulator to connect to if that's what your asking.
