why people want to disable this sensor ?
kacheoh
#1 ◈ 2025-05-21
Hi PGMFI member ,
Just want to clarify why some programmer want to disbale some sensor ?
what actually to do with it ?
if we didnt disable the sensor will it effect engine performance ?
disable knock sensor
disable ELD
disable atmospheric pressure sensor
disable injector test sensor
disable oxygen sensor (open loop)
disable oxygen sensor heater
disable VTEC speed check
disable VTEC coolant temp check
enable debug mode ( disable O2 and more )
for normal bin file i only see it has only disable this
Could someone please clarify ....
thanks .
relic1
#2 ◈ 2025-05-21
Re: why people want to disable this sensor ?
almost all OBD1 CELs will change the way the car runs.
- some hardware does not have a knock board
Quote:
disable ELD
some cars do not have the ELD (non-USDM)
some ECUs do not have the hardware (non-USDM ECUs)
necessary to tune the maps
some ECUs do not have heater control, and a wideband has it's own heater control.
if the car is having speedo problems, disabling this makes VTEC work correctly. can also be sued for non automotive honda aplications (buggies, boats)
bypass ECT sensor problems to make VTEC work correctly
manditory to tune maps
thanks .
It depends on which ECU you are using. If you open a base P30 bin, it has the sensors disabled for the JDM P30 hardware, same with a P28 or P72 bin.
All though IMO running all the time with debug mode enabled is not a good idea.
kacheoh
#3 ◈ 2025-05-21
thanx for your information
thank you ...
sangai
#4 ◈ 2025-05-21
enable debug mode ( disable O2 and more ) <--- why need to tick?? and why running with enable debug mode is a not good idea,
can someone here explain :)
