#1 ◈ 2026-03-13
The version I'm working on was started with v.2.5.2, and I'm not incorporating datalogging into it since I've been updating the ecucontrol plugin.
Refer to posts below for descriptions of updates.
also posted is the installer for v.2.5.2 incase your just starting...install v.2.5.2 if you havent and use the executable from below.
- Needs Testing:
-4 bar MAP Support
-Injector Calculations
- Tested and Working:
-Extra Tables for NG Code (iat/ect enrichment)
-Graphing
-Smoothing
-Target Idle
-Read ROM from Ostrich
-CEL Code Enable/Disable
-Customizable Increase/Decrease Increment
-Ostrich2 RTP
-Boost Cut
-Single Maps for all NG Code
- To Do List:
-Support for other MAP sensors
-PK2 Support
-Editable Closed Loop Target AFR (voltage)
-Make completely scriptable
v.3.1.1
-added 920000 baud for the newer ostrich
-added a user selectable startup file similar to bre
-added a new bin "template" style startup; so if you have any stable bins that you use to start new basemaps you can put them in a seperate folder and browse to them automatically each time...for now as soon as you create a new bin it asks to save as so that you dont overwrite your file.
-please try the high speed rtp and let me know if it works...
feeling generous?
find the changes useful?
have a special request?
throw me a couple bucks to help pay for vb6...
or just donate to the cause @ pgmfi@pgmfi.org
Donation List
9/24/08 - PGMFI - $19
2/21/09 - guest0001 - $5
2/23/09 - esi42 - $10
3/25-09 - turboD15 - $5 & chipped PM6
4/6/09 - The Acid Beaver - $20
5/30/09 - sanimalp - $15
6/6/09 - hondaworkshop.com - $10
10/6/09 - guest0001 - $2
11/27/09 - clwtwizted - $15
1/1/10 - guest0001 - $5
1/6/10 - Walterronny - $15
1/7/10 - kablammyman - $5
4/18/10 - Aragorn - $20
4/21/10 - singleslamhp - $20
5/14/10 - mazdarcing - $10
6/17/10 - fuse - PR3 ecu
8/2/10 - sophocha - $10
8/31/10 - oldmonte - $40
8/31/10 - a9turbo - $10
10/11/10 - jense - $10
10/21/10 - patprimmer - $20
2/3/11 - beboo - $30
2/12/11 - rich777 - $10
2/27/11 - gtpilot - $100
4/21/11 - steinar - $20
7/9/11 - generallee01 - $40
7/27/11 - BladeSoul - $20
10/5/11 - 90zcrex - $25
12/20/11 - RiB'$ - $30
3/9/12 - xsnsx - $75
3/27/12 - Zoltan - $50
8/6/12 - *anonymous - $5
6/8/13 - jbretthowell - $5
9/14/13 - shadow032 - $10
3/30/14 - riverrunner06 - $20
4/5/14 - DAQS - $10
10/13/16 - McAwesome - $20
See the following link for a complete installer for the latest TE: CLICK ME!
*Thanks to honda-perf.net for the use of their ftp site...and to The Acid Beaver for setting things up
