P06-P28, HULOG, Chrome problems. ready to pull hair out
slambedcivic
#1 โ—ˆ 2022-08-30
First off, Im new to all of this. Ive made a post about this before and to no avail. This time I took some pictures. Ive got a P06 converted to a P28, HULOG, and many different cables. Ive had John Kerr helping me a little bit in the past and I simply gave up on it. I came back today and tried it again with some new cables. Same thing. Maybe someone can see something that Ive done wrong? Im running a brand new HP Pavilion dv2000 with Windows Vista.
The only thing that doesnt make sense to me is the Baud rate between the PC and Chrome. The only way I can get the laptop to connect to the ECU is with a Baud of 9600 in Chrome and 38400 on the PC. This is Pictured below as well.
HULOG w/ wire colors
HULOG again *note J12*
Whole ECU
Chip
Retractable USB Cable
New Data Line
Regular USB Cable
Checksum Removed and Quickdatalogger added per JK
COM Settings in Chrome
COM settings on PC
WEIRD ASS NUMBERS @ IDLE!
relic1
#2 โ—ˆ 2022-08-30
Re: P06-P28, HULOG, Chrome problems. ready to pull hair out
strange, my port settings are the exact opposite.
38400 in Crome and 9600 in settings. (then again I only have a serial cable setup on this computer)
what did you load as a driver for the HULOG? (right from moates.net correct?)
slambedcivic
#3 โ—ˆ 2022-08-30
yes i got everything from moates.net. Ive tried uninstalling and reinstalling a few times. Ive gotten the drivers from the CD I got with my HULOG a few years ago, and from the website... maybe if i switch my bauds to the exact opposite itll work?
relic1
#4 โ—ˆ 2022-08-30
well you're obviously getting communication of some kind, I'd bet it's a setting somewhere that's corrupting the data stream. try switching the settings.
**edit**
Now that I had a chance to look at my other computer, I have my USB driver set to 38400 and Crome set the same.
slambedcivic
#5 โ—ˆ 2022-08-30
**edit**
i tried them both @ 38400 and it would not connect. im out of ideas!
zebvaj
#6 โ—ˆ 2022-08-30
Are you throwing any CEL?
slambedcivic
#7 โ—ˆ 2022-08-30
both UD and Chrome say that I am. The car is bone stock and CEL free
slambedcivic
#8 โ—ˆ 2022-08-30
I dowloaded Chrome 1.4 last night. Im gonna try that and see what I get today. I doubt it's gonna make any difference.
zebvaj
#9 โ—ˆ 2022-08-30
Are you using the same map that is on the chip to try to datalog? I heard you need to have the exact map in order to.
slambedcivic
#10 โ—ˆ 2022-08-30
i burn a fresh chip and put it in and try to log.
ntc490
#11 โ—ˆ 2022-08-30
It looks like you have the black and white wires crossed from your ECU to HULOG. They should be wired straight through. I'm using a P28 and HULOG and that's how mine's wired. See the first page of the thread in my sig for a pinout diagram of the ECU. My CN2 cable looks exactly the same on the HULOG side as it does on the ECU side.
ntc490
#12 โ—ˆ 2022-08-30
Got it working yet? Let us know! :)
slambedcivic
#13 โ—ˆ 2022-08-30
i actually did get it working. i have an older HULOG which is wired like that for some reason. i did a p72 computer and got everything running right
i think that my problem was what someone had mentioned before. I think that i was running a GSR map in the computer and trying to log with a p30.
thanks to all that have helped me!
ntc490
#14 โ—ˆ 2022-08-30
Glad to hear you got it working. :)
