badmanbaz
#1 โ 2016-04-03
i brought a p06 ecu converted it to p28 spec to fit in my car (done a minime on it using a z8 head)
brought the conversioin harness because the orignal ecu is supposed to be obd2a (so i thought)
so i take it out to swap them over to plug the p06 ecu in and my conversion harness is wrong.
the connector inside the car looks like obd1 (blue connector in pics). P1G ecu
ecu plug with two notches on plug A are slighly different??
so i decide to take a look inside strange and bit of searching and i found it looks very simlar to a p07 ecu the one out of the VX in the US
just thought this is quite interesing because the stock ecu has wideband o2
is this the missing link of the ecu world could the stock 37820-P1G-E11 be chipped to make use of the the WBO2 it has 2 highside switches i pressume for EGR an VTEC-E and another board where the barometric pressure sensor normally is and to oki mcu's one with m662-364 and m6**-248 *i belive this says 62 or 22 but its had to read through the paint that is on it
anyways pics explain better
[url]<a href="http://badmanbaz.myphotoalbum.com/view_album.php?set_albumName=album01" title="Photo Sharing by myphotoalbum.com">ecu pics</a>[/url]
sorry bit of noob
any ideas welome
anyone chipped an ecu like this
thanks baz
