Writing ROMS in XP
robert h
#1 ◈ 2025-08-04
can someone tell me what i need to be able to write roms in windows xp.. i hate having a multi boot computer..
xtensive
#2 ◈ 2025-08-04
Re: Writing ROMS in XP
GhettoDyne should work with Win95/98/ME/2000/XP
Are you getting a specific error?
Mike
robert h
#3 ◈ 2025-08-04
I want to be able to Burn the Rom.. I meant sorry. I use Win_prg and that is win 98/Me only.. is there something i can use im win xp to Burn them.. the chips
Kevin Likis
#4 ◈ 2025-08-04
Robert, I discovered a neat feature of XP which should allow you to do this. The idea is to right-click the EXE file (not the shortcut, but the actual EXE) of the program you use to burn, and click PROPERTIES. A dialog box will come up. Click the COMPATIBILITY tab (2nd tab at the top). Check the box that states "Run this program in compatibility mode for..." and choose a previous version of Windows from the drop-down box. (Win98/ME)
Note: I use XP Professional, and i'm not sure if XP Home has this feature. Reply if that helps. Hope it does.
robert h
#5 ◈ 2025-08-04
I think this helped. thanks.. i havent burned a rom yet.. but the program now opens with no errors . thanks
