What's the ratio exactly? Seems like 12 ms in Zdyne time is different than 12 ms in Ghettodyne time. It took me using half a tank in 30 miles to figure that out
Re: Conversion for going from Zdyne to Ghettodyne?
I believe that ZDyne states that their times are in milliseconds of on time for the injectors. I also understood from the "Read Me" included with the GhettoDyne .BIN that GettoDyne was setup the same way...
Kirk
My understanding is that they are the same.... maybe just a tad small bit off ... like in the 100ths place...
Not too bad though...
I think that in the boost-enabled version of ghettodyne there is a discrepancy. I think the MS-time displayed corresponds with equivalent ms of 240cc but I might be hallucinating
That's an interesting thought there, blundar. Ya, they seem to be a bit high for 450cc. I'm running it now, and my car does run a bit rich. The maps are pretty timid. But, still, they seem to be 240cc maps. Similar to the NA maps.
Yes, you are all correct! I mentioned this in a previous post, but forgot to post it on the GhettoDyne website. Basically since the MAP voltage is being scaled 5/8 the stock maps work almost perfectly for 450cc injectors and boost! Sorry about the confusion...I need to make that more clear, or display them more accurately!
Mike
