GhettoDyne, now with installer
xtensive
#1 ◈ 2025-05-16
New version of GhD 2.2.1 packed with an installer and un-installer. Adds program files menu and shortcut it you want it to. Also fixes all those stupid errors in XP, and 95.
Mike
asmcoded
#2 ◈ 2025-05-16
Re: GhettoDyne, now with installer
Pimp!!!! Are the Bins in this one updated? i remember the previous release they were having a few errors and you reposted fixed versions.
Turbo_EF9
#3 ◈ 2025-05-16
Ya, what sucks is that even the installer won't fix the registration of the OCX files if they have been previously registered in another directory.
Awww.. ya, XP owns awl.
If the installer still doesn't fix your issue, click start, then run, type: regsvr32 then drag and drop the OCX into the "Run" dialog. This will put the path to the file after regsvr32. You can just type it if you want, but I'm lazy. Anyway, click OK or press enter and you're done. Do that for all of the OCXs and it'll run fine.
habit
#4 ◈ 2025-05-16
Man i don't understand what happen. I was using Ghettodyne on XP and now it gives me that error code? I tried opening run and typing in "regsvr32" that doesn't work either? Am i doing something wrong?
Turbo_EF9
#5 ◈ 2025-05-16
You didn't follow the directions, or you're getting a different error.
