Cannot open ECUControl *have searched*
mazdarcing
#1 ◈ 2026-02-04
Hello all,
I don't post much, I have been lurking for a while...been using turboedit to tune my DOHC ZC turbo CRX with great results. Lately I have been wanting to use ECUControl to do some data logging at the track now that it is open and I am having some issues. I try to open it through turboedit and it won't load, I open the standalone version and it does load. I have tried all the walk throughs that I have found on the forum and I have had no luck. I am using Windows XP and turboedit 3.1.10. Any help is greatly appreciated, Thanks!
-Jason
#2 ◈ 2026-02-04
Re: Cannot open ECUControl *have searched*
for 6.1.17, look in the application folder and see if there is a applog.txt (or something similar, cant remember what i named it) file...and if so post what it says. then try this and post back if it worked or not...
http://forum.pgmfi.org/viewtopic.php?f=56&t=19303#p118641
basically make sure eChartControl.ocx is in the same folder as ecucontrol.dll...i think that is the one that causes it to not open. if that fixes it, drop that file in your system folder and register it using Start>Run... regsvr32 "C:\WINDOWS\system32\eChartControl.ocx", then you will never have to worry about it again.
this isnt done with the installer because i can only upload a maximum of 2mb and with all the resource files, i am well over that size. plus i dont like overwriting stuff on peoples system folders...
mazdarcing
#3 ◈ 2026-02-04
Ok I tried what you said and still no luck, and when I open the applog.txt i get this:
Application Innitialized...
4/27/2010 - 5:02:56 PM
Communicating with TurboEDIT...
I installed turboedit and ecu control the way i have been installing it here on my work computer and it worked for me there. I think i may be missing a file or I may have an incorrect file somewhere. Thanks again for the help.
-Jason
mazdarcing
#4 ◈ 2026-02-04
I've tried re-installing again, still no luck. I really wanna datalog at the track on friday, any help is greatly appreciated, Thanks!
#5 ◈ 2026-02-04
so you've moved echartcontrol.ocx and mtssdk.ocx to the correct locations and/or registered them successfully and nothing shows up still???
do you have the old standalone version installed? http://forum.pgmfi.org/download/file.php?id=6344
#6 ◈ 2026-02-04
ok, so i just spent most of my night screwing around with my laptop and figured it out (as i completely fubared my setup and brought it back to life).
make a new folder in the ecucontrol plugin folder...lets call it Resource Files for example.
move the following files into that folder:
mts.dll
mtssdk.ocx
eChartControl.ocx
NumLEDs.ocx
cars.ocx
then register each one (except mts.dll) and see if it starts...
to register... Start>Run... and type in the following
regsvr32 "C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\Resource Files\mtssdk.ocx"
then repeat
regsvr32 "C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\Resource Files\eChartControl.ocx"
then repeat
regsvr32 "C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\Resource Files\NumLEDs.ocx"
then repeat
regsvr32 "C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\Resource Files\cars.ocx"
let me know if it works... :?
mazdarcing
#7 ◈ 2026-02-04
Thank you very much, I have the stand alone version running and it functions. I will try what you said in your last post when I get home today, and post back with the results. Thanks again for all the help.
mazdarcing
#8 ◈ 2026-02-04
Sweet! That did the trick, thanks again for all the help! Look out for a donation coming your way!
Jyizorz
#9 ◈ 2026-02-04
This post has helped me solve my problem and now I am capable of data logging.
Thank you very much!
joppez
#10 ◈ 2026-02-04
I have done this x2 to got it work.. Next update maybe one installer and that installs turboedit and ecucontrol in one installer, so you dont have to install like 5 different zips and exes... :roll:
guest0001
#11 ◈ 2026-02-04
mts.dll
mtssdk.ocx
eChartControl.ocx
NumLEDs.ocx
cars.ocx
then repeat
then repeat
then repeat
This worked for me. all the files are in the new ecucontrol plugin installer, but I had to register them.
a9turbo
#12 ◈ 2026-02-04
seems i was missing the mts.dll file
taiajam
#13 ◈ 2026-02-04
I downloaded mtssdk.ocx and wanted to put it in my plugins folder and noticed that it was already there.
I replaced it anyway and it fixed the problem.
thanx!
