code 4 from p28 ecu only how to fix??
bigtroble
#1 ◈ 2024-11-11
well it only throws code 4 with this ecu
all others are fine
so I know the sensors are ok
tried tracing circuit for any visible problems but nothing
anyone has the fix for this ecu
has the 11F0-1500 board
Joseph Davis
#2 ◈ 2024-11-11
Re: code 4 from p28 ecu only how to fix??
H1C1 is faulty.
bigtroble
#3 ◈ 2024-11-11
what else does that H1C1 control what about iacv code 14?
can I use one from a p72 ecu looks pretty close??
bigtroble
#4 ◈ 2024-11-11
update.........
H1C1 fixed it
thanks again!!
any luck with code 14 on p75-p72 ecu fix??
or code 1 on p30-010 ecu fix?
