Quote:
the problem you are going to have (as was hinted above) is that there is a major difference between having an output to control the solenoid and having the software to be able to use it properly.
the first is easy, the later not so much.
Well, as I know, p72 operates EGR. Does a p72 ROM operate EGR in a p30 when added output circuit or not? It's the same question for the F22B1 SOHC VTEC ecu. (I'm not sure that an Accord rom works in a civic ecu or not)
And the next question is, how can I manage the way that the ecu controls the EGR?
