Problem with TE 3.2.1. under XP
plamenmm74
#1 ◈ 2016-04-03
Hi, somebody help with TE3.2.1. under XP pls
I downloaded TE 3.2.1., installed all, but when I'm trying to open NG XX (no matter wich ng) it says "This is not a TurboEDIT compatable ROM!"
Tried to reinstall - the same. Few friends tried to install it too - in some cases it runs normally, in some cases - the problem is the same, so I think that there is a problem with some XP's only (may be, depending of configuration, service packs, something other...?)
Pls help - is anyone met this problem? 3.1.1. is good but really need some ng63's options...
#2 ◈ 2016-04-03
Re: Problem with TE 3.2.1. under XP
do stock roms open, or older ng versions (55, 60, etc...)? if you get that message its not finding values to define which rom it is. ie...stock roms look at the first 5 or 6 address values while the ng roms look to the last 2 bytes to see which version it is and how many tables you have.
i need to test a few more things in 3.2.2, then it should be ready...
plamenmm74
#3 ◈ 2016-04-03
there is no matter which bin - 3.2.1. shows me the same message
"This is not a TurboEDIT compatible ROM!
Development - 0
Stock - 00000000"
I saw that I've got this
"Error during Form_Load @ Sector !!!
Type mismatch Error# 13"
in TEStartLog - how to fix?
Thanks in advance.
3.2.2 - sounds great!
sophocha
#4 ◈ 2016-04-03
It is strange.Most of the times when I get this message is because I`m trying to open up an old rom on a newer version of turboedit.Try older versions of turboedit and see what happens
plamenmm74
#5 ◈ 2016-04-03
Older version 3.1.10 works fine, but can't open ng63.
Still have the problem - tried everything, no change.
Tried 3.2.2. - error 13 when it loads, and won't open anything (when clicking the button ot menu option nothing happens)
Any ideas? I've already exhausted
#6 ◈ 2016-04-03
Anything before 3.2.1 won't open NG63.
If you are getting errors on load, then you probably don't have your OCX files registered correctly.
plamenmm74
#7 ◈ 2016-04-03
Still have this problem. I've registered all ocx' and dll's manualy several times /I've put them all one by one in system32/, except mts.dll - I've got a message "...mts.dll was loaded but the DLLRegisterServer entry point was not found". No change - TE3.2.2 loads with run-time error 13: file mismatch. After clicking OK it loads, but the menu opens with no further activities - for example, after clicking File menu, it drops, but wont open any file - when clicking File/Open nothing happens/
It's very strange, all older versions incl 3.1.10. work fine on my notebook. I have this problem with 3.2.1. and 3.2.2.
I'm stubborn. I realy need OBD0/ng63's ECT compensations to tune rare 1.3 OBD0 vtec engine (D13B2 EDM block +Z6 head + PM6 ECU, revs fine but there is the problem with ECT corrections). Somebody - any ideas?
Help, pls
#8 ◈ 2016-04-03
:oops: sorry for the trouble, what are your regional settings set to? go to control panel>regional and language options and post a screen shot of the menus. if they are not set to english (united states), try changing to that and see if you still get the issue.
plamenmm74
#9 ◈ 2016-04-03
My language was set to Bulgarian, after changing to English all's ok.
I'm just stupid :?
Thanks!
#10 ◈ 2016-04-03
great! glad that got it working...
I'm just stupid :?
Thanks!
nah, I would have thought something was wrong too... the language settings have burned me before, I should have tried running it under another regional setting just to see what happens.
