a9turbo wrote:
ok so for example, if i disable vtec and set the vtec indicator at x rpm, then the mil will not illuminate...?
correct
a9turbo wrote:
And whats the relationship between the vtec activation rpm and the indicator rpms? like if i set vtec at 5k and the indicator at 6k, will the cel light up at 5k or 6k?
the rpm setpoint is only utilized for the shiftlight, VTEC indicator turns on/off as the VTEC output is turned on/off (so it must be activated).
Stock:
uses stock routines, CEL off after fuel pump prime, CEL on/off due to error codes.
Shiftlight:
stock routines bypassed, CEL on/off based on setpoint RPM and current RPM.
VTEC Indicator:
stock routines bypassed, CEL on/off based on if the VTEC output (A/C or Auto) is utilized and whether it is turned on/off.
Boost Indicator:
stock routines bypassed, CEL on/off based on if you are using column 0-14 or 15-29.
