Hardware to disable code 20 ELD on stock ECU? (without chip)
sdrisk8262
#1 ◈ 2025-04-30
I am looking for a way to disable a stock ECU from reporting code 20 (ELD) from inside the ECU. I found a site that says to clip R136 & R138, but they also say to chip and disable with software. What would happen if I remove the resistors? Wouldn't it still show a code 20 since the circuit has been cut?
I'm not looking for adding relays and jumpers under the hood. But a mod inside the ECU itself.
relic1
#2 ◈ 2025-04-30
Re: Hardware to disable code 20 ELD on stock ECU? (without c
yes
Smooth1
#3 ◈ 2025-04-30
R136 and R138 have nothing to do with what you're trying to do. They allow datalogging 0-5v on the ELD input accurately.
adlionfisher
#4 ◈ 2025-04-30
It can be and is probably a way to spoof the ELD input and PA - but I have never tried it, and I know nobody. They are probably as variable resistors, which returns some excitement back to the ECU - watch component testing in a manual Helms should be revealing.
sophocha
#5 ◈ 2025-04-30
I think all the euro cars don`t have an ELD sensor so another plus for me :)
TheMike
#6 ◈ 2025-04-30
Just connect ELD pin to ground with 1k resistor inside ECU:
