ralfi2000
#1 ◈ 2012-04-12
Hello everyone! Sorry for my bad english for start
I've got a little problem with my ECU. It is P06 chipped with custom map P30. I tuned the map with innovate and it is OK, but i would like to make it better. For this I've run datalogging in CROME. I've set the open loop at all time for this map. And every values are ok, above the o2 input. It still shows values at about 3,7-3,8V. I connected it to the LM2 wideband output. The voltage on the wb output is ok(checked with multimeter, lets say about 2,5V ), when it's unconnected from the o2 input in ECU. And when I connect IT to the to o2 input, It comes to 3,8V :/ I thought, that it may be from the interferences from the o2 wire under the hood, because it's without the ground-shield, so i cutted it from ecu- still the same. Tried on another ECU P06-the same.
Please help
Please help
