SUCCESS STORY! TE 3.2.1
MrGreenGenes
#1 ◈ 2013-05-20
Hi all,
Just like to share my success with using TE 3.2.1.
the car: 1991 integra LS. 195000 miles stock engine
using dsm 450cc, msd (gm) 3bar map, 94 octane, gt28 of some sort, internally wastegated, with a 0.82a/r T2 turbine housing.
Tuned on a Dynocom hub dyno, both intertial and eddy brake loading, with TE 3.2.1, NG63 rom with imported pr4 base rom, ostrich 1.0.
Boost spiked to 18psi before dropping to a steady 15psi
WOT tuned for 11.4afr at 10psi and above...
Heres the graph!
Some things i like about the program:
Timing maps are actual timing values, whereas stock obd1 roms have an rpm base timing addition, ie: 0* extra at 1300rpm, but 15* at 9000rpm, with a linear slope.
Fuel values are actual ms pulsewidths, good to know when approaching max duty!
Gear based timing addition/subtraction!!! holy wheelspin limiter! Didn't use it, but great feature.
Things i'd like to have improved:
-Easily editable 2d maps, with a cursor on the current datapoint you want to edit, with the ability to use the arrow keys to move the cursor around this map. I personally don't like tuning fuel on the tables, whereas the 2d graphs make it easy to see that more load= more fuel. I found that once the cell tuning was finished on the dyno, i checked the 2d graphs and some load columns has crossed over each other, eg: 21" vac had more fuel than 19" vac in some spots. Makes for weird driveablity.
maybe an upload bytes countdown while in RTP mode...
Other than that, it's a great rom editor! beats ghettodyne hands down! Hahaha!
Phil
#2 ◈ 2013-05-20
Re: SUCCESS STORY! TE 3.2.1
Dude! That's good to get feedback like that!
That's some pretty decent output. Are you running the stock intake manifold? (I am pretty sure you are since torque nosedives like that.)
#3 ◈ 2013-05-20
agreed, great to see positive feedback! :wink:
I've got an updated "editor" that will improve graphing usability hands down vs the current version of TE. won't be ready for awhile, but I'm chipping away at it...
Will also have improvements for the Moates products.
turboD15
#4 ◈ 2013-05-20
Great numbers!!! It's good to hear that the program works for more than just a few people.
MrGreenGenes
#5 ◈ 2013-05-20
thanks for the input guys! i'm glad to see the obd0 stuff is still getting developed. mostly you hear people converting to obd1. Being able to tune the older stuff keeps costs down. I will be using this on my crx in the next few months... i'll keep you all posted.
phil
