Closed loop
steinar
#1 ◈ 2016-04-03
Just wondering, what are the parameters for going in and out of closed loop in the different options? Does it stay on ALL the time if I choose "ON". And what about "OFF in BOOST", does it stay in closed loop all the way up to 0 vacuum? I will try it out the in a few days anyway, just wanted to ask here first to find out if it was worth it. I'm worried it will lean out too much when it is close to 0 vacuum of it does not switch to open loop before it sees boost...
#2 ◈ 2016-04-03
Re: Closed loop
Sort of.
On, is on except at WOT. The O2 senor is mostly ignored at WOT (above a certain percentage of throttle) in all cases.
You want it off for tuning with a wideband input, or the ECU will be annoying
