Oh, WTF? I installed the logworks plug and now ECUControl
#1 ◈ 2026-03-09
Won't )(#$(*#$ open.
*sighs*
Now WTF do I do now? Everything was working perfectly. Uninstalled everything and reinstalled. I've re-regsitered all the OCX files. And now I'm stuck.
*sighs*
Any other suggestions?
#2 ◈ 2026-03-09
Re: Oh, WTF? I installed the logworks plug and now ECUContro
so you downloaded logworks.dll and installed it thru the plugins manager in TE? not sure why that would screw things up...
try this:
1. unload all the plugins in TE
2. restart TE
3. load extra tables (the dll file) thru the plugin manager
4. make sure it works
5. restart TE
6. load ecucontrol.dll thru the plugin manager
7. restart TE
8. try to start ecucontrol
if it still wont start up, then unzip the attached vbs file to any folder or desktop and run it (double click). after a few seconds it should create a .txt file in the same folder that shows all of the registered files on your computer. post that file back up so that I can make sure that things are registered correctly.
can also try a system restore if necessary...
PS, if you want to log with logworks...I have a much better standalone software for doing that.
#3 ◈ 2026-03-09
Joe-
I was up LATE last night. Ugh . . . Everything is working correctly now, but I couldn't tell you exactly what I did to get things working.
I would get to the point of registering ecucontrol.dll, and it would NOT come up when clicking on the listing for plugins. Everything seemed to be FINE, EC just would NOT pull up.
Right now, aside from last night, I have two other people at the same point. Both are using XP, both have installed everything exactly as the steps you've provided show, and EC just does not come up.
I got to the point last night where I was desperate enough to start messing with the system registry. I went through and deleted EVERYTHING related to TE, ECUControl, Logworks (This all started when I tried to install logworks and the logworks plugin), and extratables. I went through the whole computer and deleted everything that was related to TE in any way shape or form, restarted several times to make sure I didn't booger up the registry too badly, then went through the installation steps again. Still no dice. So, I installed the logworks plugin and Logworks3, then WTF . . . Everything started working again.
I have no idea why. Here is what I get when I run your script:
5/18/2011 10:59:03 AM
key count=308
[Microsoft ActiveX Data Objects 2.0 Library] {00000200-0000-0010-8000-00AA006D2EA4} C:\Program Files\Common Files\System\ado\msado20.tlb
[Microsoft ActiveX Data Objects 2.1 Library] {00000201-0000-0010-8000-00AA006D2EA4} C:\Program Files\Common Files\System\ado\msado21.tlb
[Microsoft ActiveX Data Objects 2.5 Library] {00000205-0000-0010-8000-00AA006D2EA4} C:\Program Files\Common Files\System\ado\msado25.tlb
[Microsoft ActiveX Data Objects 2.6 Library] {00000206-0000-0010-8000-00AA006D2EA4} C:\Program Files\Common Files\System\ado\msado26.tlb
[Microsoft ActiveX Data Objects Recordset 2.8 Library] {00000300-0000-0010-8000-00AA006D2EA4} C:\Program Files\Common Files\System\ado\msador15.dll
[Microsoft ADO Ext. 2.8 for DDL and Security] {00000600-0000-0010-8000-00AA006D2EA4} C:\Program Files\Common Files\System\ado\msADOX.dll
[OLE Automation] {00020430-0000-0000-C000-000000000046} C:\WINDOWS\system32\stdole32.tlb
[OLE Automation] {00020430-0000-0000-C000-000000000046} C:\WINDOWS\system32\stdole2.tlb
[Visual Basic For Applications] {000204EF-0000-0000-C000-000000000046} C:\WINDOWS\system32\msvbvm50.dll
[Visual Basic For Applications] {000204EF-0000-0000-C000-000000000046} C:\Program Files\TurboEDIT PRO\msvbvm60.dll
[Microsoft Windows Installer Object Library] {000C1092-0000-0000-C000-000000000046} C:\WINDOWS\system32\msi.dll
[Dglogs 1.0 Type Library] {01D0A772-4346-4186-94F5-A1A120BC3401} C:\WINDOWS\system32\dgnet.dll
[Skype4COM 1.0 Type Library.] {03282B5D-B38F-469D-849A-09B0A7F4881B} C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
[Microsoft ActiveMovie Control] {05589fa0-c356-11ce-bf01-00aa0055595a} C:\WINDOWS\system32\amcompat.tlb
[Adobe Acrobat 7.0 Browser Control Type Library 1.0] {05BFD3F1-6319-4F30-B752-C7A22889BCC4} C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroPDF.dll
[Microsoft Scriptlet Library] {06290C00-48AA-11D2-8432-006008C3FBFC} C:\WINDOWS\system32\scrobj.dll
[SAFSessionResolver 1.0 Type Library] {087EAABE-39BA-47C2-AB77-A93009A70F0A} C:\WINDOWS\system32\safrslv.dll
[Directory Dialog] {09EB0D18-7F65-11D3-B327-000021C5C8A9} C:\Program Files\TurboEDIT PRO\DIRDLG.OCX
[SHGINA 1.0 Type Library] {0A055C02-BABE-4480-BB7B-A8EC723CE9C0} C:\WINDOWS\system32\shgina.dll
[AppleSoftwareUpdateAdmin 1.0 Type Library] {0AF768AC-4FBD-4914-B847-F4E13C984926} C:\Program Files\Apple Software Update\SoftwareUpdateAdmin.dll
[InstallShield LogServices 1.0 Type Library] {0BE5FF71-E7BA-11D2-B40E-00A024B9DDDD} C:\Program Files\Common Files\InstallShield\engine\6\Intel 32\ILog.dll
[PGMFZ] {0C2C27D2-3EC8-4E30-A5CA-C59A16C57C37} C:\Program Files\TurboEDIT\pgmfz.dll
[Export 1.0 Type Library] {0D3DEBA1-DEBE-11D1-8B87-00C04FD7A924} C:\WINDOWS\system32\catsrvut.dll\2
[Microsoft Script Control 1.0] {0E59F1D2-1FBE-11D0-8FF2-00A0D10038BC} C:\WINDOWS\system32\msscript.ocx
[PDFPrevHndlr 1.0 Type Library] {0F6D3808-7974-4B1A-94C2-3200767EACE8} C:\Program Files\Adobe\Reader 9.0\Reader\pdfprevhndlr.dll
[WmdmLog 1.0 Type Library] {110A3201-5A79-11D3-8D78-444553540000} C:\WINDOWS\system32\wmdmlog.dll
[WiaVideo 1.0 Type Library] {1320AD9E-A50F-4ED0-B1A4-4E45EC25005E} C:\WINDOWS\system32\wiavideo.dll
[Microsoft DirectAnimation Media Controls] {139DD5D1-D6E2-11D0-89D4-00A0C90833E6} C:\WINDOWS\system32\daxctle.ocx
[MSAAText 1.0 Type Library] {150E2D7A-DAC1-4582-947D-2A8FD78B82CD} C:\WINDOWS\system32\msaatext.dll
[logworks] {15448E33-6A60-43B0-B0A9-4434390D107D} C:\Program Files\TurboEDIT PRO\Plugins\Logworks\logworks.dll
[LM Library] {183C2598-0480-11D1-87EA-00C04FC29D46} C:\WINDOWS\system32\lmrt.dll
[SchemaManager 1.0 Type Library] {1856AD2E-6F53-4EA2-B76D-B6D7FA07C391} C:\WINDOWS\system32\wmiscmgr.dll
[nvdmcpl 1.0 Type Library] {19B0E9BE-C52F-4552-9C47-932A8859E781} C:\WINDOWS\system32\nvwdmcpl.dll
[NvCpl 1.0 Type Library] {1AFBF72B-58EA-41CB-B117-3CDE0857F4A6} C:\WINDOWS\system32\nvcpl.dll
[NvCpl 1.2 Type Library] {1AFBF72B-58EA-41CB-B117-3CDE0857F4A6} C:\WINDOWS\system32\nvcpl.dll
[RDSServerHost 1.0 Type Library] {1B16CE61-2406-412F-969E-21BC082F76E8} C:\WINDOWS\system32\rdshost.exe
[System Monitor Control] {1B773E42-2509-11CF-942F-008029004347} C:\WINDOWS\system32\sysmon.ocx
[NATUPnP 1.0 Type Library] {1C565858-F302-471E-B409-F180AA4ABEC6} C:\WINDOWS\system32\hnetcfg.dll\2
[Microsoft MIMEEDIT Type Library 1.0] {1C82EAD8-508E-11D1-8DCF-00C04FB951F9} C:\WINDOWS\system32\inetcomm.dll
[MTxAddIn Type Library] {1CB0A010-1676-11D0-825B-00A0C90395DF} C:\WINDOWS\system32\comaddin.dll
[Accessibility] {1EA4DBF0-3C3B-11CF-810C-00AA00389B71} oleacc.dll
[wiaview 1.0 Type Library] {1F1C00F8-8876-11D2-8067-00805F6596D2} C:\WINDOWS\system32\camocx.dll
[DfrgUI 1.0 Type Library] {202D3AE0-2F0E-11D1-A1F6-0080C88593A5} C:\WINDOWS\system32\dfrgui.dll
[UPnP 1.0 Type Library] {204810B3-73B2-11D4-BF42-00B0D0118B56} C:\WINDOWS\system32\upnpcont.exe
[System_Windows_Forms] {215D64D2-031C-33C7-96E3-61794CD1EE61} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.tlb
[Microsoft NetShow Player] {2179C5D0-EBFF-11cf-B6FD-00AA00B4E220} C:\WINDOWS\system32\nscompat.tlb
[Messenger Type Library] {218CB45F-20B6-11d2-8E17-0000F803A446} C:\Program Files\Messenger\msmsgs.exe
[Microsoft TAPI 3.0 Type Library] {21D6D480-A88B-11D0-83DD-00AA003CCABD} C:\WINDOWS\system32\tapi3.dll
[MTS SDK v1.0] {21DA5218-0A6C-4240-9486-D6BFD4FA83FC} C:\Program Files\LogWorks3\mtssdk.ocx
[Microsoft OLE DB Service Component 1.0 Type Library] {2206CEB0-19C1-11D1-89E0-00C04FD7A829} C:\Program Files\Common Files\System\Ole DB\oledb32.dll
[Microsoft ActiveX Data Objects (Multi-dimensional) 2.8 Library] {22813728-8BD3-11D0-B4EF-00A0C9138CA4} C:\Program Files\Common Files\System\ado\msadomd.dll
[System_Web] {2295CFB6-8B0C-307C-A610-96360B10F9B9} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Web.tlb
[Windows Media Player] {22D6F304-B0F6-11D0-94AB-0080C74C7E95} C:\WINDOWS\system32\msdxm.ocx
[CompatUI 1.0 Type Library] {233A5627-7755-4B36-AA00-656B8846F501} C:\WINDOWS\system32\compatui.dll
[JET Expression Service Type Library] {2358C810-62BA-11D1-B3DB-00600832C573} C:\WINDOWS\system32\msjtes40.dll
[PPServer 1.0 Type Library] {23D1AE21-8023-11D3-8D47-00C04F949D33} C:\WINDOWS\help\sniffpol.dll
[Msie ActiveX Control module] {25959BEC-E700-11D2-A7AF-00C04F806200} C:\Program Files\Common Files\Microsoft Shared\MSInfo\ieinfo5.ocx
[DisplayServer 1.0 Type Library] {25EBA1D0-EB51-4CBE-8515-23E81DF77F97} C:\Program Files\NVIDIA Corporation\Display\nvdisps.dll
[ISAFrdm 1.0 Type Library] {2607D38D-2EA5-4F41-81DD-F96A31E6DE1B} C:\WINDOWS\system32\safrdm.dll
[SStub 1.0 Type Library] {26D19E41-819E-11D3-8D49-00C04F949D33} C:\WINDOWS\help\sstub.dll
[InstallShield Runtime 1.0 Type Library] {27D2CF3C-D5B0-11D2-8094-00104B1F9838} C:\Program Files\Common Files\InstallShield\engine\6\Intel 32\ctor.dll
[TAPI3 Terminal Manager 1.0 Type Library] {28DCD85B-ACA4-11D0-A028-00AA00B605A4} C:\WINDOWS\system32\termmgr.dll
[COMMSIGen 1.0 Type Library] {29894293-C0FE-11D1-8D87-0060088F38C8} C:\WINDOWS\system32\catsrvut.dll\5
[AcroIEHelperShim 1.0 Type Library] {2991F100-D9C3-4243-82A2-A718747FC0CF} C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
[COM+ Services Type Library] {2A005C00-A5DE-11CF-9E66-00AA00A3F464} C:\WINDOWS\system32\COMSVCS.DLL
[Microsoft ActiveX Data Objects 2.8 Library] {2A75196C-D9EB-4129-B803-931327F72D5C} C:\Program Files\Common Files\System\ado\msado15.dll
[Microsoft HTML Object Library] {3050F1C5-98B5-11CF-BB82-00AA00BDCE0B} C:\WINDOWS\system32\mshtml.tlb
[OptsHold 1.0 Type Library] {3050F4E0-98B5-11CF-BB82-00AA00BDCE0B} C:\WINDOWS\system32\mshtmled.dll
[Messenger Extensions Type Library] {3201590C-8C63-4558-8142-82C29FC695E9} C:\Program Files\Messenger\msmsgs.exe\4
[scp 1.0 Type Library] {32BAED35-34B5-11D3-9315-00C04F72D6CF} C:\WINDOWS\system32\msscp.dll
[Tabular Data Control 1.1 Type Library] {333C7BC1-460F-11D0-BC04-0080C7055A83} C:\WINDOWS\system32\tdc.ocx
[TIME] {33ADBFCC-3E0D-11D2-B948-00C04FA32195} C:\WINDOWS\system32\datime.dll
[WMPProxyLib] {3478E7B3-E18E-4548-A446-DDB5B4A59D9E} C:\WINDOWS\system32\browsewm.dll
[DirectAnimation Library] {34F681D0-3640-11CF-9294-00AA00B8A733} C:\WINDOWS\system32\danim.dll
[proctexe 1.0 Type Library] {35CA7A28-2B58-4FA6-A2D7-B843E60D0AC4} C:\WINDOWS\system32\proctexe.ocx
[CertCli 1.0 Type Library] {372FCE32-4324-11D0-8810-00A0C903B83C} C:\WINDOWS\system32\certcli.dll
[TSHOOT 3.1 Type Library] {37536092-0A44-11D3-854B-004005506310} C:\WINDOWS\help\TShoot.dll
[MSWebDVD 1.0 Type Library] {38EE5CE1-4B62-11D3-854F-00A0C9C898E7} C:\WINDOWS\system32\mswebdvd.dll
[Indexing Service Administration Type Library 1.0] {3BC4F393-652A-11D1-B4D4-00C04FC2DB8D} C:\WINDOWS\system32\ciodm.dll
[MyComput 1.0 Type Library] {3BFC964D-7A55-11D0-B928-00C04FD8D5B0} C:\WINDOWS\system32\mycomput.dll
[cic 1.0 Type Library] {3D5905E0-523C-11D1-9FEA-00600832DB4A} C:\WINDOWS\System32\cic.dll
[Microsoft VBScript Regular Expressions 1.0] {3F4DACA7-160D-11D2-A8E9-00104B365C9F} C:\WINDOWS\system32\vbscript.dll\2
[Microsoft VBScript Regular Expressions 5.5] {3F4DACA7-160D-11D2-A8E9-00104B365C9F} C:\WINDOWS\system32\vbscript.dll\3
[MS TTS Engine 1.0 Type Library] {3F7C4D29-D007-11D2-B503-00C04F797396} C:\Program Files\Common Files\SpeechEngines\Microsoft\TTS\1033\spttseng.dll
[Microsoft Theme API Type Library] {40643250-8D23-47FB-895C-EAF48E2C8892} C:\WINDOWS\system32\themeui.dll
[ComSnap 1.0 Type Library] {410381CD-AF42-11D1-8F10-00C04FC2C17B} C:\WINDOWS\system32\comsnap.dll
[AcroBrokerLib] {41738EEA-442F-477F-92CF-2889BD6CD7E7} C:\Program Files\Adobe\Reader 9.0\Reader\AcroBroker.exe
[PDFShellServer 1.0 Type Library] {41C5FFFE-36DD-415D-9ED0-2976A342A1C8} C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.dll\2
[Microsoft Scripting Runtime] {420B2830-E718-11CF-893D-00A0C9054228} C:\Program Files\TurboEDIT PRO\scrrun.dll
[NodeMgr 1.0 Type Library] {43136EB0-D36C-11CF-ADBC-00AA00A80033} mmcndmgr.dll
[triedit 1.0 Type Library] {438DA5D1-F171-11D0-984E-0000F80270F8} C:\Program Files\Common Files\Microsoft Shared\Triedit\triedit.dll
[NetCon 1.0 Type Library] {43E734CA-043D-4A70-9A2C-A8F254063D91} C:\WINDOWS\system32\hnetcfg.dll
[mmAEPlugIn 1.0 Type Library] {44C79591-D0DE-49C4-BA3C-A45AB7003356} C:\Program Files\Movie Maker\wmm2ae.dll
[ATL 2.0 Type Library] {44EC0535-400F-11D0-9DCD-00A0C90391D3} C:\WINDOWS\system32\ATL.DLL
[Microsoft Internet Transfer Control 6.0 (SP6)] {48E59290-9880-11CF-9754-00AA00C00908} C:\Program Files\TurboEDIT PRO\MSINET.OCX
[Legacy MtxGrp 1.0 Type Library] {4B2E957D-0393-11D1-B1AB-00AA00BA3258} C:\WINDOWS\system32\comsvcs.dll
[Wave MSP 2.0 Type Library] {4DDB6D35-3BC1-11D2-86F2-006008B0E5D2} C:\WINDOWS\system32\wavemsp.dll
[EventSystem 1.0 Type Library] {4E14FB90-2E22-11D1-9964-00C04FBBB345} C:\WINDOWS\system32\es.dll
[ixsso Control Library] {4E469DD1-2B6F-11D0-BFBC-0020F8008024} C:\WINDOWS\system32\ixsso.dll
[DirectShowStream 1.0 Type Library] {4E6CDE29-C0C4-11D0-8FF1-00C04FD9189D} C:\WINDOWS\system32\amstream.dll
[Microsoft AutoDiscovery Type Library] {4EAFB888-81CB-4EBA-BAC9-DA254E5721F1} C:\WINDOWS\system32\autodisc.dll
[System_EnterpriseServices] {4FB2D46F-EFC8-4643-BCD0-6E5BFA6A174C} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.tlb
[ezPMUtils.WindowGroup Type Library] {506B4C1F-587D-4CD3-94A3-00354CF6EFEF} C:\Program Files\Skype\Plugin Manager\ezPMUtils.dll
[Microsoft Shell Controls And Automation] {50A7E9B0-70EF-11D1-B75A-00A0C90564FE} C:\WINDOWS\system32\SHELL32.dll
[RegwizCtrl 1.0 Type Library] {50E5E3C0-C07E-11D0-B9FD-00A0249F6B00} C:\WINDOWS\system32\regwizc.dll
[Preview 1.0 Type Library] {50F16B18-467E-11D1-8271-00C04FC3183B} C:\WINDOWS\system32\shimgvw.dll
[RAssistance 1.0 Type Library] {5190C4AF-AB0F-4235-B12F-D5A8FA3F854B} C:\WINDOWS\system32\racpldlg.dll
[dsdmoprp 1.0 Type Library] {53A5D8DE-EF98-4729-8C35-5D069F05FA07} C:\WINDOWS\system32\dsdmoprp.dll
[Messenger Private Type Library] {53CED51D-432B-45b2-A3E0-0CE2C24235D4} C:\Program Files\Messenger\msmsgs.exe\2
[CertMgr 1.0 Type Library] {53D6AB1C-2488-11D1-A28C-00C04FB94F17} C:\WINDOWS\system32\certmgr.dll
[Microsoft DirectX Transforms Core Type Library] {54314D1D-35FE-11D1-81A1-0000F87557DB} C:\WINDOWS\system32\Dxtrans.dll
[Common Language Runtime Execution Engine 2.0 Library] {5477469E-83B1-11D2-8B49-00A0C9B7C9C4} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscoree.tlb
[Microsoft Data Access Components Installed Version] {54AF9343-1923-11D3-9CA4-00C04F72C514} C:\WINDOWS\system32\odbcconf.dll
[LW2 Virtual Device] {55920B35-3475-48ED-8F51-BB039D2C1F07} C:\Program Files\LogWorks3\vdevctrl.dll
[WSHControllerLibrary] {563DC060-B09A-11D2-A24D-00104BD35090} C:\WINDOWS\system32\wshcon.dll
[Video_TVServer 1.0 Type Library] {56494266-49C1-4C68-8C11-5E1B7B878E02} C:\Program Files\NVIDIA Corporation\Display\nvvitvs.dll
[Microsoft WMI Scripting V1.2 Library] {565783C6-CB41-11D1-8B02-00600806D9B6} C:\WINDOWS\system32\wbem\wbemdisp.TLB
[ActiveMovie control type library] {56A868B0-0AD4-11CE-B03A-0020AF0BA770} C:\WINDOWS\system32\quartz.dll
[Private SDO 1.0 Type Library] {56BC53D1-96DB-11D1-BF3F-000000000000} C:\WINDOWS\system32\iassdo.dll\2
[FlashAccessibility] {57A0E746-3863-4D20-A811-950C84F1DB9B} C:\WINDOWS\system32\macromed\flash\flash.ocx\2
[FlashAccessibility] {57A0E746-3863-4D20-A811-950C84F1DB9B} C:\Program Files\Adobe\Reader 9.0\Reader\authplay.dll\2
[JavaWebStart 1.0 Type Library] {5852F5E0-8BF4-11D4-A245-0080C6F74284} C:\Program Files\Java\jre6\bin\wsdetect.dll
[NetFwTypeLib] {58FBCF7C-E7A9-467C-80B3-FC65E8FCCA08} C:\WINDOWS\system32\hnetcfg.dll\3
[AMIViewer ActiveX Control module] {5B0E4730-2F12-453F-B8C7-698382126BB7} C:\WINDOWS\Downloaded Program Files\AmiViewerLite21.ocx
[xenroll 1.0 Type Library] {5B9169C0-DB65-42AA-A38A-0726846AAEB3} C:\WINDOWS\system32\xenroll.dll
[WMICntl 1.0 Type Library] {5C65924B-E236-11D2-8899-00104B2AFB46} C:\WINDOWS\system32\wbem\wbemcntl.dll
[Windows Media Player Launcher] {5CB42160-CD7C-4806-9367-1C4A65153F4A} C:\WINDOWS\system32\wmpshell.dll
[UpdateLib] {5CCFC82E-2648-445E-9925-6E3E8D33F4E1} C:\WINDOWS\system32\muweb.dll
[NetMeeting 1.1 Type Library] {5CE55CD7-5179-11D2-931D-0000F875AE17} C:\Program Files\NetMeeting\conf.exe
[trialoc 1.0 Type Library] {5E23BBAD-AA35-11D1-ADEA-0000F87734F0} C:\Program Files\Internet Explorer\Connection Wizard\trialoc.dll
[Windows Genuine Advantage Validation Tool] {5E649A63-7EE9-43F4-9926-0DEAA462A8FB} C:\WINDOWS\system32\LegitCheckControl.dll
[Microsoft DirectX Transforms Image Transforms Type Library] {5E77EB03-937C-11D1-B047-00AA003B6061} C:\WINDOWS\system32\Dxtmsft.dll
[Microsoft FlexGrid Control 6.0 (SP6)] {5E9E78A0-531B-11CF-91F6-C2863C385E30} C:\Program Files\TurboEDIT PRO\msflxgrd.ocx
[NCProv 1.0 Type Library] {5F099F16-6A6E-4BBC-8BD8-98F3221D58C4} C:\WINDOWS\system32\wbem\ncprov.dll
[AcroIEHelper 1.0 Type Library] {5F226421-415D-408D-9A09-0DCD94E25B48} C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
[English US WordBreaker 1.0 Type Library] {613201F0-A246-11D3-BB8C-0090272FA362} C:\WINDOWS\system32\LangWrbk.dll
[wrap_activex 1.0 Type Library] {61FA3F13-8061-4796-B055-3697ED28CB38} C:\Program Files\OpenOffice.org 3\program\so_activex.dll
[UpdateLib] {62488C27-257D-4E5D-AB1A-6E89F9429E15} C:\WINDOWS\system32\wuweb.dll
[eTree eChart v1.0] {6273F1D8-1EFE-43AD-BF68-F1DC254E5C38} C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\eChartControl.ocx
[CustReg 1.0 Type Library] {640D3148-A423-11D2-B943-00C04F79D22F} C:\WINDOWS\system32\catsrvut.dll\7
[Microsoft Multicast Address Allocation Client COM Wrapper 1.0 Type Library] {64217CC0-A285-11D1-8697-006008B0E5D2} C:\WINDOWS\system32\mdhcp.dll
[GamesConfigServer 1.0 Type Library] {6481B880-0FE2-48FE-A15F-D8254FC98884} C:\Program Files\NVIDIA Corporation\Display\nvgames.dll
[Microsoft Comm Control 6.0 (SP3)] {648A5603-2C6E-101B-82B6-000000000014} C:\Program Files\TurboEDIT PRO\MSCOMM32.OCX
[Microsoft Chart Control 6.0 (SP4) (OLEDB)] {65E121D4-0C60-11D2-A9FC-0000F8754DA1} C:\Program Files\TurboEDIT PRO\MSCHRT20.OCX
[Microsoft WinHTTP Services, version 5.1] {662901FC-6951-4854-9EB2-D9A2570F2B2E} C:\WINDOWS\system32\WINHTTP.dll
[Indeo® video custom control type library] {665A4446-D905-11D0-A30E-444553540000} ir50_32.dll
[PDFShell 1.0 Type Library ] {67E94227-7662-4050-9C72-746983CF37A2} C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\pdfshell.dll
[MMC Internal Web Browser event sink 1.0 Type Library] {680C64B0-8DA2-4399-BF4B-E94C1E52983E} C:\WINDOWS\System32\mmc.exe\4
[Setup UI 1.0 Type Library] {682C25C5-D7D9-11D2-80C5-00104B1F6CEA} C:\Program Files\Common Files\InstallShield\engine\6\Intel 32\iuser.dll
[DHTML Edit Control for IE5] {683364A1-B37D-11D1-ADC5-006008A5848C} C:\Program Files\Common Files\Microsoft Shared\Triedit\dhtmled.ocx
[krnlprov 1.0 Type Library] {6B100E1A-1385-4D1F-A02E-6E705A76BB6C} C:\WINDOWS\system32\wbem\krnlprov.dll
[IAS Core Components 1.0] {6BC09690-0CE6-11D1-BAAE-00C04FC2E20D} C:\WINDOWS\system32\iassvcs.dll
[ IAS Helper COM Component 1.0 Type Library] {6BC096BB-0CE6-11D1-BAAE-00C04FC2E20D} C:\WINDOWS\system32\iashlpr.dll
[IAS DataStore2 1.0] {6BC096C5-0CE6-11D1-BAAE-00C04FC2E20D} C:\WINDOWS\system32\iasads.dll
[ IAS RADIUS Protocol 1.0 Type Library] {6BC09890-0CE6-11D1-BAAE-00C04FC2E20D} C:\WINDOWS\system32\iasrad.dll
[IAS Network Access Policy 1.0] {6BC098A0-0CE6-11D1-BAAE-00C04FC2E20D} C:\WINDOWS\system32\iasnap.dll
[Windows Media Player] {6BF52A50-394A-11D3-B153-00C04F79FAA6} C:\WINDOWS\system32\wmp.dll
[ScriptPW 1.0 Type Library] {6E3EC78A-6CE7-4298-815B-21BEF4967112} C:\WINDOWS\system32\scriptpw.dll
[MSIEFTP 1.0 Type Library] {6E8CEDE1-746A-11D1-91F7-006097DF5BD4} C:\WINDOWS\system32\msieftp.dll
[MTS 2.0 Admin Type Library] {6EB22880-8A19-11D0-81B6-00A0C9231C29} C:\WINDOWS\system32\Com\mtsadmin.tlb
[mswmdm 1.0 Type Library] {6EC6C744-355F-11D3-8470-00C04F79DBC0} C:\WINDOWS\system32\mswmdm.dll
[sessmgr 1.0 Type Library] {71F1098A-2D69-45D7-B19E-D3B902323F66} C:\WINDOWS\system32\sessmgr.exe
[Windows Media Player Compatibility Layer] {73F0DD5C-D071-46B6-A8BF-897C84EAAC49} C:\WINDOWS\system32\wmpdxm.dll
[cryptext 1.0 Type Library] {7444C709-39BF-11D1-8CD9-00C04FC29D45} C:\WINDOWS\system32\cryptext.dll
[Performance Logs and Alerts 1.0 Type Library] {7478EF60-8C46-11D1-8D99-00A0C913CAD4} C:\WINDOWS\system32\smlogcfg.dll
[Legacy Microsoft Transaction Server Type Library] {74C08640-CEDB-11CF-8B49-00AA00B8A790} C:\WINDOWS\system32\comsvcs.dll
[oleprn 1.0 Type Library] {7586B340-EC08-11D0-A466-00C04FC30DF6} C:\WINDOWS\system32\oleprn.dll
[Windows Media Services DRM Storage object] {760C4B74-E211-11D2-BF3E-00805FBE84A6} C:\WINDOWS\system32\drmstor.dll
[Dexter 1.0 Type Library] {78530B68-61F9-11D2-8CAD-00A024580902} C:\WINDOWS\system32\qedit.dll
[PDFFilter 1.0 Type Library] {789AD2D7-E1C2-4EC7-A049-2DB5BB4CB57A} C:\Program Files\Adobe\Reader 9.0\Reader\AcroRdIF.dll
[Windows Media Streamer Plugin Type Library] {790EF936-F7A1-4489-90A1-5C77CE75B500} C:\WINDOWS\system32\wmstream.dll
[Microsoft Disk Quota 1.0] {7988B57C-EC89-11cf-9C00-00AA00A14F56} dskquota.dll
[Legacy Transaction Context Type Library] {7999FC20-D3C6-11CF-ACAB-00A024A55AEF} C:\WINDOWS\system32\comsvcs.dll
[zClientM 1.0 Type Library] {7A26EA67-A78A-4B89-A5E2-ED7EE09EC08A} C:\Program Files\MSN Gaming Zone\Windows\zclientm.exe
[msinfo32 1.0 Type Library] {7AC18319-0739-4377-8984-848573D519A5} C:\WINDOWS\PCHealth\HelpCtr\Binaries\msinfo.dll
[Microsoft Data Source Interfaces] {7C0FFAB0-CD84-11D0-949A-00A0C91110ED} C:\WINDOWS\system32\msdatsrc.tlb
[SoftwareUpdate] {7C1E4FCC-B47E-44AE-8EA7-FA66EBC8BAC4} C:\Program Files\Apple Software Update\SoftwareUpdate.exe
[AFormAut 1.0 Type Library] {7CD06992-50AA-11D1-B8F0-00A0C9259304} C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins\AcroForm.api
[iextag 1.0 Type Library] {7E8BC440-AEFF-11D1-89C2-00C04FB6BFC4} C:\WINDOWS\system32\iepeers.dll
[wiaacmgr 1.0 Type Library] {80D45A3E-3CD8-4FF4-9E99-43A2109049D6} C:\WINDOWS\system32\wiaacmgr.exe
[IAS SDO 1.0 Type Library] {81DDF732-4AA8-4A35-BDFF-8B42EFE7C624} C:\WINDOWS\system32\iassdo.dll\1
[scardssp 1.0 Type Library] {82C38704-19F1-11D3-A11F-00C04F79F800} C:\WINDOWS\system32\scardssp.dll
[Microsoft Windows Common Controls 6.0 (SP6)] {831FDD16-0C5C-11D2-A9FC-0000F8754DA1} C:\Program Files\TurboEDIT PRO\MSCOMCTL.OCX
[Help Service 1.0 Type Library] {833E4000-AFF7-4AC3-AAC2-9F24C1457BCE} C:\WINDOWS\pchealth\helpctr\binaries\HelpSvc.exe
[RemoteProxy6432 1.0 Type Library] {8628F27C-64A2-4ED6-906B-E6155314C16A} oleacc.dll\2
[MSTIME] {87C96271-ADDB-4745-B2E8-DF88A8472FD1} C:\WINDOWS\system32\mstime.dll
[MSPMSP 1.0 Type Library] {896E7419-3851-11D3-AA54-00C04FD22F6C} C:\WINDOWS\system32\mspmsp.dll
[msnetobj 1.0 Type Library] {8AA720BF-7468-4DA1-97DA-66D2E41B3DDA} C:\WINDOWS\system32\msnetobj.dll
[Microsoft Terminal Services Active Client 1.0 Type Library] {8C11EFA1-92C3-11D1-BC1E-00C04FA31489} C:\WINDOWS\system32\mstscax.dll
[Microsoft AntiMalware 1.0 Type Library] {8C389764-F036-48F2-9AE2-88C260DCF400} c:\PROGRA~1\MICROS~2\MsMpCom.dll
[COLBCAT 1.0 Type Library] {8C758293-9351-11D1-9D1A-006008B0E5CA} C:\WINDOWS\system32\clbcatex.dll
[tom] {8CC497C9-A1DF-11CE-8098-00AA0047BE5D} C:\WINDOWS\system32\riched20.dll
[Microsoft Information Card IE Helper 1.0 Type Library] {8D810F97-C1A1-49CA-9902-A7B7E58AF009} C:\WINDOWS\system32\icardie.dll
[RTCShare 1.0 Type Library] {8DE06D9A-7FB0-4A94-A7A3-33B5A1BF90D1} C:\WINDOWS\system32\rtcshare.exe
[COM MakeCab 1.0 Type Library] {8E17FFE3-C5BA-11D1-8D8A-0060088F38C8} C:\WINDOWS\system32\catsrvut.dll\6
[Microsoft Management Console 2.0] {8E80422B-CAC4-472B-B272-9635F1DFEF3B} C:\WINDOWS\System32\mmc.exe
[Microsoft LTScommon Object Library] {9153CE57-F693-4A8E-8B7C-29C8486566D0} C:\Program Files\Common Files\SpeechEngines\Microsoft\spcommon.dll
[Setup Kernel 1.0 Type Library] {91814EB1-B5F0-11D2-80B9-00104B1F6CEA} C:\Program Files\Common Files\InstallShield\engine\6\Intel 32\iKernel.exe
[WMTImportLib] {91D84D20-B64E-4552-8089-4697107B280A} C:\Program Files\Movie Maker\MOVIEMK.exe\1
[STClient 1.0 Type Library] {92AD68AA-17E0-11D1-B230-00C04FB9473F} C:\WINDOWS\system32\stclient.dll
[Microsoft Remote Data Services Server 2.7 Library] {9381D8F6-0288-11D0-9501-00AA00B911A5} C:\Program Files\Common Files\System\msadc\msadcf.dll
[Software Shadow Copy provider 1.0 Type Library] {93BB06B6-B6DA-43C8-BC9B-E32DB49AA6F7} C:\WINDOWS\system32\SWPRV.DLL
[StarBurnX 12.0 Type Library] {93CBA48A-1C58-4648-B22D-8F3588CB8D95} C:\Program Files\CDBurnerXP\StarBurnX.dll
[InstallShield Setup Kernel] {94636247-BC39-4B8B-A728-2D1FBEBFA76A} C:\Program Files\Common Files\InstallShield\Professional\RunTime\IsProBE.tlb
[MMFUtil 1.0 Type Library] {94F6FF32-37C3-11D2-8840-00104B2AFB46} C:\WINDOWS\system32\mmfutil.dll
[Microsoft Windows Image Acquisition 1.01 Type Library] {95CEDD63-2E34-4B84-9FB3-F86AF1D4BF7A} C:\WINDOWS\system32\wiascr.dll
[ScriptSigner] {95CEF0E5-A4ED-4703-B501-AE70A153697A} C:\WINDOWS\system32\wshext.dll
[Visual Basic runtime objects and procedures] {97177EBC-0C54-11D0-B407-00AA00C14969} C:\WINDOWS\system32\msvbvm50.dll\2
[RDCClientHost 1.0 Type Library] {97917068-BB0B-4DDA-8067-B1A00C890F44} C:\WINDOWS\system32\rdchost.dll
[Volume Shadow Copy Service 1.0 Type Library] {97AEFDD8-2F60-11D3-8A39-00C04F72D8E3} C:\WINDOWS\system32\vssvc.exe
[Active DS Type Library] {97d25db0-0363-11cf-abc4-02608c9e7553} C:\WINDOWS\system32\activeds.tlb
[ComPlus 1.0 Catalog Replication Type Library] {98315905-7BE5-11D2-ADC1-00A02463D6E7} C:\WINDOWS\system32\comrepl.dll
[ComExpS 1.0 Type Library] {99847C25-B1B4-11D1-8F10-00C04FC2C17B} C:\WINDOWS\system32\comuid.dll
[Microsoft Tuner 1.0 Type Library] {9B085638-018E-11D3-9D8E-00C04F72D980} C:\WINDOWS\system32\msvidctl.dll\2
[Microsoft Feeds 2.0 Object Library] {9CDCD9C9-BC40-41C6-89C5-230466DB0BD0} C:\WINDOWS\system32\msfeeds.dll
[AmiDicomDirTreeView 2.1 Type Library] {A0F313D9-4F85-45B5-963B-E905CEEF2F39} C:\WINDOWS\Downloaded Program Files\AmiDicomDirTreeView21.ocx
[msdfmap 1.0 Type Library] {A1A6B98C-497F-11D1-9217-00C04FBBBFB3} C:\Program Files\Common Files\System\msadc\msdfmap.dll
[CMProps 1.0 Type Library] {A1B9E012-3226-11D2-883E-00104B2AFB46} C:\WINDOWS\system32\cmprops.dll
[ServDeps 1.0 Type Library] {A1B9E03C-3226-11D2-883E-00104B2AFB46} C:\WINDOWS\system32\servdeps.dll
[MovieMaker 2.0 MMFX Type Library] {A2D4529E-84E0-4550-A2E0-C25D7C5CC0D0} C:\Program Files\Movie Maker\wmm2fxa.dll
[NUSRMGR 1.0 Type Library] {A5064420-D541-11D4-9523-00B0D022CA64} C:\WINDOWS\system32\nusrmgr.cpl
[PDFPrevHndlrShim 1.0 Type Library] {A58FB5B3-CF96-4C63-B0D2-232A1AEA1A1B} C:\Program Files\Adobe\Reader 9.0\Reader\pdfprevhndlrshim.exe
[GMS Numeric LED ActiveX Control] {A68A1580-4572-11D0-B597-00A024A54A93} C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\NumLEDs.ocx
[Microsoft Agent Server 2.0] {A7B93C73-7B81-11D0-AC5F-00C04FD97575} C:\WINDOWS\msagent\AgentSvr.exe
[Adobe 3D Utility 1.0 Type Library] {A7D71146-EBCD-4E6C-916C-E77865BCC53B} C:\Program Files\Adobe\Reader 9.0\Reader\A3DUtility.exe
[AMiViewerLite 2.1 Type Library] {AABD9E81-294C-461C-A16C-E4E56A6878AF} C:\WINDOWS\Downloaded Program Files\AmiViewerLite21.ocx\2
[Microsoft Jet and Replication Objects 2.6 Library] {AC3B8B4C-B6CA-11D1-9F31-00C04FC29D52} C:\Program Files\Common Files\System\ado\msjro.dll
[Maxx Zephyr Technology MDITaskBar Control v 1.2.02] {AD19E1EA-26D9-11D4-8736-DE39EA222B33} C:\Program Files\TurboEDIT\OpenSource3.1\MDITaskBarControl.ocx
[Maxx Zephyr Technology MDITaskBar Control v 1.2.02] {AD19E1EA-26D9-11D4-8736-DE39EA222B33} C:\Program Files\TurboEDIT PRO\MDITaskBarControl.ocx
[HHCtrl 4.0 Type Library] {ADB880A2-D8FF-11CF-9377-00AA003B7A11} C:\WINDOWS\system32\hhctrl.ocx
[NMSDVD DVD Burning SDK Pro - ActiveX Edition] {AE827ABA-9A56-40FF-8F45-B7DE58CD9BDB} C:\Program Files\CDBurnerXP\NMSDVDXU.dll
[Disk Management Snap-In Object Library] {AEB84C80-95DC-11D0-B7FC-B61140119C4A} C:\WINDOWS\System32\dmview.ocx
[Microsoft Browser Helpers] {B025F75A-CD86-4D11-A0C8-D7644FDBFB5A} C:\WINDOWS\system32\browseui.dll
[spmServices.DRMClientV2 Type Library] {B0A632A5-B0D1-41E8-A84A-A502B3341363} C:\Program Files\Skype\Plugin Manager\ezPMUtils.dll
[MS Video Control 1.0 Type Library] {B0EDF154-910A-11D2-B632-00C04F79498E} C:\WINDOWS\system32\msvidctl.dll
[SendCMsg 1.0 Type Library] {B1AFF7C2-0C49-11D1-BB12-00C04FC9A3A3} C:\WINDOWS\system32\sendcmsg.dll
[WUAPI 2.0 Type Library] {B596CC9F-56E5-419E-A622-E01BB457431E} C:\WINDOWS\system32\wuapi.dll
[ecucontrol] {B67B80ED-2331-4D95-890B-ECE757D5A8CA} C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\ecucontrol.dll
[WMPDeskBand 1.0 Type Library] {B6DD1ED6-573F-40FD-99A1-F28D8BF23916} C:\PROGRA~1\WINDOW~2\wmpband.dll
[blockdriver 1.0 Type Library] {B842074C-8E12-4178-A6D8-7C0D7C87C43E} C:\WINDOWS\system32\hotplug.dll
[Legacy MTSEvents 1.0 Type Library] {BACEDF3E-74AB-11D0-B162-00AA00BA3258} C:\WINDOWS\system32\comsvcs.dll
[crome Library] {BB6C2389-BBC6-4047-9C9A-BD582C94C57F} C:\Program Files\CROME\crome.exe
[Microsoft Remote Data Services 2.7 Library] {BD96C556-65A3-11D0-983A-00C04FC29E30} C:\Program Files\Common Files\System\msadc\msadco.dll
[Microsoft Tabbed Dialog Control 6.0 (SP6)] {BDC217C8-ED16-11CD-956C-0000C04E4C0A} C:\Program Files\TurboEDIT PRO\tabctl32.ocx
[mscorlib.dll] {BED7F4EA-1A96-11D2-8F08-00A0C9A6186D} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.tlb
[System] {BEE4BFEC-6683-3E67-9167-3C0CBC68F40A} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.tlb
[sdtmach 1.0 Type Library] {BF981FCC-B743-11D1-A69A-00C04FB9988E} C:\WINDOWS\system32\catsrvut.dll\4
[ScriptingObjectModel] {C1D8C091-AC66-4159-B738-E70A12B983A4} C:\Program Files\Apple Software Update\ScriptingObjectModel.dll
[Microsoft Sdpblb 1.0 Type Library] {C259D79A-C8AB-11D0-8D58-00C04FD91AC0} C:\WINDOWS\system32\sdpblb.dll
[Import 1.0 Type Library] {C2BE6961-DF9E-11D1-8B87-00C04FD7A924} C:\WINDOWS\system32\catsrvut.dll\3
[IP NAT Helper] {C3422E9A-4E85-4DD4-9305-DE7E18E071A4} c:\windows\system32\ipnathlp.dll
[Microsoft_Vsa_Vb_CodeDOMProcessor] {C4F9D6EB-4FBB-3341-A582-AEA37ED6DA94} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Vsa.Vb.CodeDOMProcessor.tlb
[Acrobat Access 3.0 Type Library] {C523F390-9C83-11D3-9094-00104BD0D535} C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins\Accessibility.api
[Tolerance 1.0 Type Library] {C58F1580-0DF3-401C-93B1-2D9DDA61CF04} C:\Program Files\Windows Media Player\mpvis.dll
[Microsoft Soap Type Library] {C65657D9-5C4B-421E-8DA6-AD4D590FE854} C:\Program Files\Common Files\MSSoap\Binaries\mssoap1.dll
[licdll 1.0 Type Library] {C7879482-F798-4A74-AF43-E887FBDCED40} C:\WINDOWS\system32\licdll.dll
[Microsoft Speech Object Library] {C866CA3A-32F7-11D2-9602-00C04F8EE628} C:\Program Files\Common Files\Microsoft Shared\Speech\sapi.dll
[OLE DB Errors Type Library] {c8b522d5-5cf3-11ce-ade5-00aa0044773d} C:\Program Files\Common Files\System\Ole DB\oledb32.dll\2
[brp_sysinfo 1.0 Type Library] {CA9F6CB1-47F1-4874-90CB-C674E9A86495} C:\WINDOWS\PCHealth\HelpCtr\Binaries\brpinfo.dll
[RegDBCrm 1.0 Type Library] {CB39A774-E5E4-11D1-8CC0-00C04FC3261D} C:\WINDOWS\system32\catsrv.dll\2
[Active Setup Control Library] {CC0918E0-EFE5-11CF-A044-00AA00B6015C} C:\WINDOWS\system32\asctrls.ocx
[Microsoft CDO for Windows 2000 Library] {CD000000-8B95-11D1-82DB-00C04FB1625D} C:\WINDOWS\system32\cdosys.dll
[WMSClientNetManager 1.0 Type Library] {CD12A3C0-9C42-11D2-BEED-0060082F2054} C:\WINDOWS\system32\wmnetmgr.dll
[webvw 1.0 Type Library] {CD603FC0-1F11-11D1-9E88-00C04FDCAB92} C:\WINDOWS\system32\webvw.dll
[ctv OLE Control module] {CD6C7865-5864-11D0-ABF0-0020AF6B0B7A} C:\WINDOWS\system32\dmocx.dll
[DfrgSnap 1.0 Type Library] {CD83A785-6F75-11D2-A385-00609772642E} C:\WINDOWS\system32\dfrgsnap.dll
[ComExp 1.0 Type Library] {CFADAC75-E12C-11D1-B34C-00C04F990D54} C:\WINDOWS\system32\catsrvut.dll
[rcbdyctl 1.0 Type Library] {D149C2B1-25BB-4D8C-9684-2696FDA4AF60} C:\WINDOWS\system32\rcbdyctl.dll
[WorkStationServer 1.0 Type Library] {D1F48243-B994-45CD-8A55-03DBB33745BE} C:\Program Files\NVIDIA Corporation\Display\nvwss.dll
[Shockwave Flash] {D27CDB6B-AE6D-11CF-96B8-444553540000} C:\WINDOWS\system32\Macromed\Flash\Flash10l.ocx
[Microsoft_Vsa] {D3295D86-D604-11D4-A704-00C04FA137E4} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.Vsa.tlb
[Microsoft_JScript] {D3295D87-D604-11D4-A704-00C04FA137E4} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Microsoft.JScript.tlb
[System.Drawing.dll] {D37E2A3E-8545-3A39-9F4F-31827C9124AB} c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\System.Drawing.tlb
[SENS Events Type Library] {D597DEED-5B9F-11D1-8DD2-00AA004ABD5E} C:\WINDOWS\system32\SENS.DLL
[RSM 1.0 Type Library] {D61A27C0-8F53-11D0-BFA0-00A024151983} C:\WINDOWS\system32\rsmui.exe
[Microsoft XML, version 2.0] {D63E0CE2-A0A2-11D0-9C02-00C04FC99C8E} C:\WINDOWS\system32\msxml.dll
[Microsoft Agent Server Extensions 2.0] {D6589123-FC70-11D0-AC94-00C04FD97575} C:\WINDOWS\msagent\AgentSvr.exe\2
[DMGArtEffects 1.0 Type Library] {D74CA70F-2236-4BA8-A297-4B2A28C2363C} C:\Program Files\Movie Maker\wmm2fxb.dll
[JQSIEStartDetector 1.0 Type Library] {D85100D8-894D-4F80-9697-C220AF4202EB} C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
[UPnP 1.0 Type Library] {DB3442A7-A2E9-4A59-9CB5-F5C1A5D901E5} C:\WINDOWS\system32\upnp.dll
[SAFRCFileDlg 1.0 Type Library] {DBEB2F21-60F6-4690-AB98-E512B476809F} C:\WINDOWS\system32\safrcdlg.dll
[ExtraTables] {DBF914EF-89CA-4724-83FE-6A424F29C72A} C:\Program Files\TurboEDIT PRO\Plugins\Extra Tables\extratables.dll
[InstallShield Script 1.0 Type Library] {DED1EA29-3F89-11D3-BBB9-00105A1F0D68} C:\Program Files\Common Files\InstallShield\IScript\IScript.dll
[VideoLAN VLC ActiveX Plugin] {DF2BBE39-40A8-433B-A279-073F48DA94B6} C:\Program Files\VideoLAN\VLC\axvlc.dll
[Messenger API Type Library] {E02AD29E-80F5-46c6-B416-9B3EBDDF057E} C:\Program Files\Messenger\msmsgs.exe\3
[DirectX 7 for Visual Basic Type Library] {E1211242-8E94-11D1-8808-00C04FC2C602} C:\WINDOWS\system32\dx7vb.dll
[DirectX 8 for Visual Basic Type Library] {E1211242-8E94-11D1-8808-00C04FC2C603} C:\WINDOWS\system32\dx8vb.dll
[PGMFZ] {E26EDED5-0488-48D0-8C78-7AD56239747C} C:\Program Files\TurboEDIT\pgmfz.dll
[Microsoft IP Conferencing Service Provider 1.0 Type Library] {E36489BB-45C9-11D2-831F-00A0244D2298} C:\WINDOWS\system32\confmsp.dll
[Microsoft H323 Service Provider 1.0 Type Library] {E36489BC-45C9-11D2-831F-00A0244D2298} C:\WINDOWS\system32\h323msp.dll
[FaxControl 1.0 Type Library] {E4DE3030-0142-4ACA-BA48-8613B56A2555} C:\WINDOWS\system32\Setup\fxsocm.dll
[WMI ADSI Extension Type Library] {E503D000-5C7F-11D2-8B74-00104B2AFB41} C:\WINDOWS\system32\wbem\wbemads.tlb
[Adobe Acrobat 8.0 Type Library] {E64169B3-3592-47d2-816E-602C5C13F328} C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.dll
[CatalogServer 1.0 Type Library] {E6BE109B-165F-11D1-B22D-00C04FB9473F} C:\WINDOWS\system32\catsrv.dll
[Visual Basic runtime objects and procedures] {EA544A21-C82D-11D1-A3E4-00A0C90AEA82} C:\Program Files\TurboEDIT PRO\msvbvm60.dll\3
[Microsoft Internet Controls] {EAB22AC0-30C1-11CF-A7EB-0000C05BAE0B} C:\Program Files\TurboEDIT PRO\shdocvw.dll
[Search Assistant 1.0 Type Library] {ECA4E801-17AE-4863-9F5C-AF4047AABEE0} c:\windows\srchasst\srchui.dll
[DfsShlEx 1.0 Type Library] {ECCDF535-45CC-11CE-B9BF-0080C87CDBA6} C:\WINDOWS\system32\dfsshlex.dll
[ecucontrol] {ED4A744C-319C-450F-879A-516F4E884A82} C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\ecucontrol.dll
[Microsoft ActiveX Data Objects 2.7 Library] {EF53050B-882E-4776-B643-EDA472E8E3F2} C:\Program Files\Common Files\System\ado\msado27.tlb
[Microsoft Rendezvous control 1.0 Type Library] {F1029E4D-CB5B-11D0-8D59-00C04FD91AC0} C:\WINDOWS\system32\rend.dll
[Microsoft XML, v2.6] {F5078F18-C551-11D3-89B9-0000F81FE221} C:\WINDOWS\system32\msxml2.dll
[Microsoft XML, v3.0] {F5078F18-C551-11D3-89B9-0000F81FE221} C:\WINDOWS\system32\msxml3.dll
[Microsoft XML, v6.0] {F5078F18-C551-11D3-89B9-0000F81FE221} C:\WINDOWS\system32\msxml6.dll
[Microsoft Agent Control 1.5] {F5BE8BC2-7DE6-11D0-91FE-00C04FD701A5} C:\WINDOWS\msagent\AgtCtl15.tlb
[Microsoft Agent Control 2.0] {F5BE8BC2-7DE6-11D0-91FE-00C04FD701A5} C:\WINDOWS\msagent\agentctl.dll
[COM + 1.0 Admin Type Library] {F618C513-DFB8-11D1-A2CF-00805FC79235} C:\WINDOWS\system32\Com\comadmin.dll
[FPAPI 2.0 TYPE LIBRARY] {F6FD0A0C-43F0-11D1-BE58-00A0C90A4335} C:\PROGRA~1\COMMON~1\MICROS~1\WEBSER~1\40\bin\FP4AWEC.DLL
[GMS Automobile Gauges ActiveX Control] {F84BA0A0-7408-11CF-BC8B-207402C10627} C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\cars.ocx
[Microsoft Common Dialog Control 6.0 (SP6)] {F9043C88-F6F2-101A-A3C9-08002B2F49FB} C:\Program Files\TurboEDIT PRO\Comdlg32.ocx
[Windows Script Host Object Model] {F935DC20-1CF0-11D0-ADB9-00C04FD58A0B} C:\WINDOWS\system32\wshom.ocx
[MobileServer 1.0 Type Library] {F9C24C76-8C9C-45CE-8A36-CB2FF2FDB24F} C:\Program Files\NVIDIA Corporation\Display\nvmobls.dll
[FlashBroker] {FAB3E735-69C7-453B-A446-B6823C6DF1C9} C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_ActiveX.exe
[Help Center Behaviors 1.0 Type Library] {FC7D9000-3F9E-11D3-93C0-00C04F72DAF7} C:\WINDOWS\PCHealth\HelpCtr\Binaries\HelpCtr.exe\2
[Help Center UI 1.0 Type Library] {FC7D9E00-3F9E-11D3-93C0-00C04F72DAF7} C:\WINDOWS\PCHealth\HelpCtr\Binaries\HelpCtr.exe\1
[TlntSvr 1.0 Type Library] {FE9E4895-A014-11D1-855C-00A0C944138C} C:\WINDOWS\system32\tlntsvr.exe
I am VERY interested in ANYTHING that will work more consistently than EC right now. This is just getting to be so frustrating, as there are cars that need to be tuned, and up to this point, it hasn't been this difficult.
Thank you for your help and support, man. I don't want to imply anything negative to you. I am REALLY grateful to be able to still be tuning OBD0 ECUs with TE. I love TE, and when EC works, it's great! I just wanted to make sure I get that across. I sound too whiney. LOL!
#4 ◈ 2026-03-09
Point taken. most of the issues with ecucontrol seem to stem from adding support for the serial logging of innovate channels (and regional settings for people outside the US).
Most of the time when this happens, the eChartControl.ocx file is not registered or is registered but missing. I attempted to test for all the required files when ecucontrol starts up...but it didn't seem to work with that file. Both TE and ecucontrol should have simple startup log files.
If you are gonna tune guys with logworks capabilities, does something like this interest you?
http://www.d-series.org/forums/engine-management/147429-anyone-using-logworks-3-0-a.html#post2313752
The other software that I'm working on is coming...I will email you some screenshots, and maybe ask for some suggestions.
#5 ◈ 2026-03-09
To use the Logworks program, I would have to use a 3.5mm to DB-9 to USB setup, right? That's not going to work for the guys in oddball parts of the world I work with. I just need EC to work without any headaches. No one I tune with uses the serial logging stuff. It's all just feeding the wideband to the stock O2 sensor line and using one USB to serial adapter and that's it. It works, or, it used to work.
I just need something simple that works without anything extra. I need to log everything as simply as possible. I don't need extra hardware to get in the way of tuning cars, especially when it is NOT available in places (Like Slovakia, Romania, Russia, and Brunei), or it takes months to get something imported.
*shrugs* I only know of two people who bother messing with the serial crap. (You and Justin.)
I'm very curious as to what you've got cooking up. VERY.
#6 ◈ 2026-03-09
The innovate products come with a program cable (2.5mm to DB-9). I just use a simple DB-9 to USB adapter (available for cheap anywhere in the US) and pull in up to 8 (or more) extra channels of data (AFR, EGT, ect.) directly into ecucontrol (or send the ecu data to logworks). No grounding issues, no extra wiring, no finding power sources, no ecu modifications...just need 2 usb (or serial) ports. Actually I plug the innovate chain into my laptop and use a hub to connect the ecu and emulator to my second usb port...pull 2 cables from under the floor mat and your ready to tune.
I used to use the analog out channel thru C16 and was constantly checking to make sure that the values were correct...now I just have it going to a simple gauge.
I'm 100% with you on keeping it simple, ecucontrol got a little carried away on my end trying to add support for things that I thought were useful and what others wanted...especially since the base program was written by synoptic not myself. That and being a rookie on the software development side, proper error handling went by the wayside...and thats really something that should have been more important. This was all developed with vb6, which has been losing interest and support for years now. The new software is being developed with .net (2010), so we shouldn't have all the resource file garbage happening once finished.
:lol:
#7 ◈ 2026-03-09
I bought my LC-1 used. It never came with the adapter. I have one, don't know if it works yet. I hope to not have to find out.
A hub is a good idea. Duh. I forgot about that.
It's just that I can't use logworks for the guys who don't have the right stuff.
turboD15
#8 ◈ 2026-03-09
I have my Ostrich, Hulog and DB9 adapter going into a hub and a single cord going to my laptop. I plug one cable in and I am ready to go. I paid less than $5 dollars on ebay for my db9 adapter. I'm sure your customers can spring for one of those.
The direct connect with an lc-1 is priceless imo even in Ecucontrol. No more offsets.
Joe- check you email man!!! :D
#9 ◈ 2026-03-09
It's not always a matter of affordability, it's importing stuff. That's a problem. A real problem.
I'll have to suck it up and try this out. But, for now, I'm sticking with old skool stuff to get some work done! LOL!
gtpilot
#10 ◈ 2026-03-09
I run a hub as well - single USB line that comes out from under the carpet...one port for a USB-serial adapter to the ECU, one port for the wideband and one port for the Ostrich...I have not had an issue since I got it up and running.
Kirk
#11 ◈ 2026-03-09
*shrugs* I only know of three people who bother messing with the serial crap. (You, Justin and Kirk.)
:lol: do whatever works best for you, just know that the option is there and it may/may not have benefits.
#12 ◈ 2026-03-09
I'm just scared of serial stuff. I've never been able to get anything working before. (Mostly because I'm a 'tard. Mostly.)
I am glad there are options. I am just going to try to suck it up and deal with them. I've got to try a USB to serial adapter anyway since I have to check the firmware and settings on my LC-1. Time to GSD. (Get Stuff Done.)
#13 ◈ 2026-03-09
here is where I'm at...getting closer to a testable version every day.
#14 ◈ 2026-03-09
Wooooooooooooooah . . .
sophocha
#15 ◈ 2026-03-09
I didn`t think about a hub! That`s an excellent idea....although I am a little skeptical about it.I had 2 hard drives once and a printer on a hub and whenever I was printing something the hard drives where shutting down.How do you connect the usb hub?Through an extension cable to the laptop?That might be a problem as well as some long extension cables don`t hold the proper voltage that usb connections need.I guess I`ll try it tomorrow with a small hub and see if it works.
No more 3 cables going to 3 separate usb ports!
