90zcrex wrote:
Did a little driving on the map this afternoon. As is, the boost region was pretty lean, 15:1 ish, So I richened it up a bit and getting close to 12:1 now. Getting some bucking and skipping on some part throttle areas, will have to mess with that some more when I get a chance.
How accurate is the injector duty cycle in turboedit? According to the map I would be at 100% duty cycle at 20 psi. 880cc injectors should be good up to 500 hp or more. At 20 psi I shouldn't be anywhere near that unless I built a miracle motor of some sort.
It's accurate enough for injectors up to about 450cc. I really wouldn't bother paying too much attention to the duty cycle.
How is it idling now?
You should be able to set ECUControl to log the wideband input. I was fair sure it did so automatically.
