Hint: rewire power, ground, and injectors with other inputs on the harness. Make the same modification to the inside of the ecu.
Fry their injector driver, map, and TPS sensors along with the power driver circuit and that will accomplish what you desire.
I myself, did this, and a handful of other things to my sol...
I tell friends if they can drive it away, it's theirs. I don't even pull my ecu out
. I created a pic microcontroller to sense my inputs and have anti start sort of like Neptune, but it goes off range of input and input, not just a sequence of inputs. All wiring and mods are safe behind the airbox; requiring dash removal just to get at it. No other way to bypass.
