cel comes on a 3.25k
guest0001
#1 ◈ 2026-03-02
I don't have a good laptop, so I currently have to do tuning the hard long way of bring my ostrich inside my home to use my laptop. anyway, I succesfully uploaded the rom and played with timing. I exported the bin and imported it into the newest bin ng63_final_5 ??? w/ version 3.2.2. I have launch control, boost cut, etc. all off. the cel is set to stock in ROM properties. I even tried changing the rev liming in N to 7413. driving down the road if the rpm go above say 3250 the cel kickon and stays on. no differnece in how it runs, just comes on.
I also noticed that the cel stays on during the key on pre test/main relay cycle. but it starts and runs fine. I even tried reseting the ecu.
#2 ◈ 2026-03-02
Re: cel comes on a 3250k
You downloaded an NG65_final5 bin which has the the CEL set as a shift light at that RPM.
You have to download the updated ExtraTables plugin handler and change the properties with that.
guest0001
#3 ◈ 2026-03-02
Re: cel comes on a 3.25k
I loaded the script but I dont see where to change shift points? Is it Rev limit per gear?
#4 ◈ 2026-03-02
It is listed under "Dash CEL." If you don't have that listing, you don't have Extratables v1.13.
guest0001
#6 ◈ 2026-03-02
ok, derrrrr, I loaded the wrong script. got, a shift light is pretty cool, though if it deactivated in 5th it would work better.
