New to HomeBrew Chipping
bboyzell
#1 ◈ 2025-03-23
Hi
I know this seems to be a dead part of the this forum, but i thought i will post here.
Currently been trying to chip my PR3 ecu, but getting constant CEL and Solid ECU
So far tried chipping two with the same result then purchased a PR3 with some bs fuel saver chip but it still gave me the same result.
But anyway im determined to get it going in my b16 CRX
Cheers
johnny_loo
#2 ◈ 2025-03-23
Re: New to HomeBrew Chipping
PR3 obd0?
first step to check is ur solder contact.
2nd step is check ur CHIP. make sure its 27C256 if u use 27C512, u need to off set HEX 8000 when burn chip.
3rd check correct rom burn. (u cannot get a OBD1 rom file put in to OBD0 ecu)
i have done many chipping... most is rom issue... like example JDM version have KS board, if u put JDM rom into USDM that dun have KS board without turn off KS in editor, that will make solid cel.
**correct me if im wrong. :D
sicknastyb17
#3 ◈ 2025-03-23
There is no obd0 usdm p30 and the usdm obd1 p30 has a knock board. If you have a rom with the knock enabled and a ecu without a knock board it will NOT cause a soild cel, just a knock sensor code.
Make sure the rom you are running is the same obd as the ecu.
johnny_loo
#4 ◈ 2025-03-23
JDM OBD1 P30 have KS board. and USDM P30 have in OBD0 model? from when i know how to chip ECU start until today i never see a P30 with OBD0 model, interested if it have in USDM, mind to snap some pic and mail me? million thanks....
sicknastyb17
#5 ◈ 2025-03-23
I meant to type obd0 pr3
bboyzell
#6 ◈ 2025-03-23
Hi Guys!
Thanks for the reply's, i have been checking a couple of the ecu's i have.
Turned out there was a poor soldering on the PW0 ecu i had, that was giving me high resistance, found it and fixed it yesterday.
Installed in the CRX today and went perfect, same with the two chips i had burnt for it. so one down one to go.
But most importantly i can finally start getting in to tuning this car and learn the process :)
johnny_loo
#7 ◈ 2025-03-23
bboyzell wrote:
Hi Guys!
good luck. i had experienced once too when 2 months ago... contact failure due to board copper linkage damage. tiny damage and need to use micro scope to find out.... haha... that waste me whole day....
