HI all,
I just got my MTX-L WBset and a DKU5 cable.
I used TE in the past to tune my car and others... but now i want to use the ecucontrol datalog.
I installed the plugins which goes flawless on XP, but when i load my binfile i cant open the Ecucontrol.... I can click it, but nothing happends...
plz help!
Re: te3.2.2 + ecucontrol on xp.. ecuctronol not showing..
install logworks 3 if not already...post back what happens.
http://www.innovatemotorsports.com/support.php
Do I need to hookup the MTX_L wideband set and USB DKU5 cable first to see the ecucontrol plugin popup?
Or just when I click on ECUcontrol pluging (afther I loaded my binfile) it should popup?
Ill start downloading logworks3
No.
It will pop up if everything is installed correctly, even with nothing plugged in.
ok, it doenst popup.. should i try a older version of TE?
i just installed logworks3. when i open it it says:
No serial port, IMS USB device, or IMS Network device detected.
I Click on OK and the programm opens..
I have the DKU5 USB nokia cable. didnt install the drivers yet... but i guess TE isnt working correctly?
read the text on the 1st and 2nd link you just posted.
I downloaded mtssdk.ocx and wanted to put it in my plugins folder and noticed that it was already there.
I replaced it anyway and it fixed the problem.
thanx!
