shadow032
#1 ◈ 2026-02-25
Hello everyone,
This is my first topic here
I'm reading all over the forum from three days now and I'm very excited.
I see that there is NG63 bin in development and this is so exciting !!!
Now to the point. I had an old version of TE and desided to update it but had little luck.
I missed that I need to have the 2.5.5 installed first, and then update to 3.2.2, but even when I tried that it didn't work.
I tried installing, uninstalling, searching through the registry for TE and deleting all the entries ... but still nothing.
I keep getting this error "There was an error getting the value from your script function... Please check your calculations and try again"
when I try to load the extratables plugin.
I've seen the program running normal on another computer and it has charts inside the NG63 extratables plugin.
They don't show on my rig and I keep getting this error.
I tried searching through the forum and google for this error but nothing came up. Sorry if this issue has already been discussed.
Can you give me an advice how to proceed? I wish not to reinstall my OS, altho that might fix the problem.
EDIT I'm running Windows 7 x64 on AMD AM3 platform.
Thanks.
SOLVED !!! Decimal symbol must be "." instead of "," which is default in Windows7.
It is located in Control Panel->Clock,Language,Region->Region and Language->Formats->Additional Settings->Decimal Symbol
Just type in "." there and it works like a charm
Thanks a9turbo and slawekbb !!! You rock !!!
Thanks.
