Here is a screen shot of what I've run into. Any ideas? BTW I have TE running on a old laptop running XP SP3 just fine, I would like consolidate to lugging around a single laptop though.
Re: TE v3.2.2 Window 7 32bit installer error
Went into properties for the TE installer, compatibility tab and set it to run as XP SP3. Continued merrily along with the install until I got to the ET extratables.dll
The solution is below:
Click Start
Type command in the search
Right click on command prompt and click run as administrator
If the prompt reads C:\Windows\System32> Proceed, if not enter the following: cd "%systemroot%\System32
At the prompt type: regsvr32 "C:\Program Files\TurboEDIT PRO\Plugins\Extra Tables\extratables.dll" hit enter
At the prompt type: regsvr32 "C:\Program Files\TurboEDIT PRO\Plugins\EcuControl\ecucontrol.dll" hit enter
All should be good in the world, for now.
http://forum.pgmfi.org/viewtopic.php?f=56&t=20408Sixth post down and everything is fully fuctioning
