Still setting CEL1 with o2 disable
Zoltan
#1 ◈ 2026-03-03
I am running ng3 with TE3.2.2. Trying to disable the O2 sensor CEL, but I still get the CEL1 even after setting CEL1=0 in the 'check engine light' tab under 'ROM Properties'. For what it is worth, I have also set 'o2 options' to 'off' in the 'general options' tab. Any thoughts to what I am doing wrong?
skull-candy18
#2 ◈ 2026-03-03
Re: Still setting CEL1 with o2 disable
I get the same problem. It takes a while for the error to appear though and it only happens when the engine is hot and in gear coasting.
I think its an inherent fault and ca never be truly disabled.
crisaguilar
#3 ◈ 2026-03-03
same problem here :cry:
generallee01
#4 ◈ 2026-03-03
has anyone fixed this problem?? I just recently had to re-install TE on another computer and Im having this issue
