EcuControl data logging query
skull-candy18
#1 ◈ 2026-02-08
Turboedit has been datalogging fine for 3 weeks then today in the map section it decides it doesn't want to map columns. So its recording afr and rpm but not afr and vacuum.
Very frustrating as it was working perfectly.
I've tried un-installing ecuControl but to no avail.
Should I completely un-Install turboedit and start again ?
#2 ◈ 2026-02-08
Re: EcuControl data logging query
can you post a screen shot or the csv file that shows what you are describing?
skull-candy18
#3 ◈ 2026-02-08
Sorry for the delay,I bought a house and have been busy moving.
I've tried re-installing everything but to no avail, so I bought a new laptop which I have just finished installing everything on which I will try at the weekend.
How do I get a csv file?
skull-candy18
#4 ◈ 2026-02-08
Had another go with a brand new laptop. Same problem. Column and row data is not being picked up by Ecucontrol.
Interestingly If I use the latest NG63 rom I get row data and then I'm just missing column.
Ultimately I believe It may be the Moates Hulog or the cable that connects to the ecu unless any one has come across this issue before?
Strange how the NG63 rom works better than the older roms, otherwise I would think its a wiring issue 100%.
I've uploaded a screenshot anyway.
