sjrobinson
#1 ◈ 2016-04-01
First thing is a connection problem. I'm trying both bluetooth and usb connections. With the USB connection I am using tunerview on my phone. It says I'm connected but I get no data.
So I try freelog on my computer. You can see the screenshot. Theres no data, it will connect and a few of the data points will show up but not change. So I know its the correct port but I'm thinking something with the ECU? "Sanity check" said it failed and to check the communication or baud rate.
Edit: I tried adding datalogging to the bin in crome and then burning it but that didn't seem to work.
Any ideas?
