hi all
tactix
#1 ◈ 2019-08-19
hi peeps great site
ive got a b16a2 in my eg she was originally a dx
the engines stock with 2.5" cat back and c.a.i
i have just installed a demon2 in the p30 got it running fine on a stock map for now as i dont want to mess about to much without a wideband o2
so i was wondering if i can just wire a bosch lsu sensor right to the ecu ( demon aux input ) for the 5 volt wideband line and then provide the wideband with the other inputs ie live and earth needed to power the sensor ??
i will be using crome hence why im here asking as i dont want the hastle of asking about crome based mapping in the hrtuning site
i eventualy want to build a h2b or a b20vtec over the winter (uk) or turbo my b16 ( but i like all motor builds more )
also must read / watch tutorials out there that people can suggest
CHEERS N BEERS :d
tactix
#2 ◈ 2019-08-19
Re: hi all
ok realised i would need some way to calibrate the wideband so just hooking it to the ecu wouldnt cut it
so ive bit the bullet and bought a https://www.plxdevices.com/Wideband-O2- ... 002726.htm
lucky enough amazon had one for £90
