Hello PGMFI members.. im looking for an ecu box for my ph16 vtec manual. What box are compatible with it? thank you
Re: ECU for PH16 VTEC
Hi t4b,
Ph16 vtec is a d16y5/y8, but I am not entirely sure but they are engine codes for the Philippines. You can use p2m stock box or use any obd1 that has vtec and just use an ECU jumper cable from obd2b/a (depending on the year model 96-98 obd2a 99-2000 obd2b). If you need a base map for your obd1 chipped ecu just look for d16y5/8.
OT:
Where in the Philippines are you from?
