Hstim - ECU stimulator OBD0 & OBD1 Compatible
alecsander114
#1 ◈ 2020-08-09
Perfect for those who want to test ecus after repair/remaps possibly directly on bench without the need of an actual engine.
Works on OBD0 and OBD1 ecus!
Power input : 12v dc (needs a 12v 2a power adapter)
RPM : 0 – 12 390
Inputs/ Outputs :
4 injectors
IAT
ECT
TPS
ICM
MIL + switch - to check codes
VTEC function - available as separate module
Module only : 150 usd
Module + box : 200 usd
Module + box + Loom(leads to connect directly to ecu) : 240 usd
Ships from Europe only with tracking number/ i will not post it otherwise (buyer pays postage).
alecsander114
#2 ◈ 2020-08-09
Re: Hstim - ECU stimulator OBD0 & OBD1 Compatible
Still have a few left..
iDavyJ
#3 ◈ 2020-08-09
still available want 1 in holland
contact me @ davish@upcmail.nl
