Stock D16A6 with a accel 500 thruster and fuel regulator
Bandofshadows
#1 ◈ 2021-01-20
So I'm wondering if I can put a Accel 500 as a replacement in my fuel tank with a fuel regulator and run my stock D16A6 on it for the time being until I build an H22A for it. Then the fuel pump will be used for it. It's going to be a while until I get there being that my budget gets in the way a lot. So it's slow and steady. Comments concerns? What do you guys think? Jw I just don't want to drop my fuel tank twice or cut a bigger hole in the access panel.
xtckustomzcrx
#2 ◈ 2021-01-20
Re: Stock D16A6 with a accel 500 thruster and fuel regulator
im curious as to why you would want that big of a pump in it anyway, even with a boosted h22 it seems a bit overkill. but anyway, your stock a6 has a return fuel system anyways like most vehicles do. the excess fuel would just return to the tank. so yes you can run it if you'd like too. but personally I would just stay with the stock pump. or if I was really building a badass h22 id run a walbro 255 at most. just my opinion. hope this helps.
