JDM ECU AT for RTP?
phatintegra
#1 ◈ 2021-01-15
I have a 1999 Acura Integra GS (OBD2) with a fully built Frankenstein LS/VTEC with a JDM SIR-G Automatic Transmission running on a chipped (basemap) JDM P30 AT ECU (OBD1) provided by Xenocron. My goal was to run Moates Demon 1. Found out it's no longer in production. I don't know what other options I have for RTP.
I thought about Hondata since I have a separate TCM. Not sure if it will control the lockup solenoids, adjust the shift point, etc. I can't find any wire diagram schematics online to understand on how the whole thing works with the ECU and TCM.
Should I say screw it and get the Moates Ostrich 2.0 and Hulog? Then again don't know if this will work on the JDM A/T ECU.
Smooth1
#2 ◈ 2021-01-15
Re: JDM ECU AT for RTP?
HAMotorsports.com is said to have some AT compatible options available.
