V8Fettler
#1 ◈ 2024-11-06
Hi there,
I’m looking for help/advice on how to utilise an Electric Power steering Rack from a Civic EP3 in a custom install, without the main Honda ECU etc.
I need a way of replicating the signals which are fed from the main ECU to the Power Steering ECU.
I’m more than capable of mechanical issues, such as fitting sensors etc, what I need is some way of replicating the signals correctly.
This will possibly include information on the Pin-out of both the main ECU,and the PS ECU.
I’ve seen someone has created a little ‘box of tricks’ to use with Vauxhall’s Corsa Electric column assists, but I need to use the EP3 rack.
Questions I have:
Is the signal from the VSS/RPM sensor to the Main ECU the same as what is fed to the PS ECU, as I can simply send his direct.
If not, is there a way of replicating these signals with simple electronics?
Thanks!
Craige
Questions I have:
Thanks!
Craige
