bmgjet
#1 ◈ 2025-10-06
Thought id share this little .net core app that lets you simulate with software a couple different emulators.
Makes it easy to debug if your writing a program that interfaces with them,
PS iv removed the encrypted transfere functions since that could be used to rip bins from certain programs.
using System;
using System.IO;
using System.IO.Ports;
using System.Text;
using System.Threading;
namespace EmulatorSimulator
class Program
public static string Header = @"
BMGJET 2020" + "\n"; //Header image
public static string HS = " Emulator Simulator 0.1\n\n"; //Header string
public static string FS = "\n(Enter The Number To Select Option)"; //Help tip.
public static bool NoDelay = false;
private static SerialPort serialPort_0;
public static byte Protocol;
public static byte[] Bin;
public static byte[] Version;
public static int TimeOut = 60;
public static string BinFile;
public static byte[] OK = new byte[] { 0x4F };
public static byte[] Serial = new byte[] { 0x04, 0x01, 0x02, 0x08, 0x08, 0x01, 0x04, 0x05, 0x06, 0x07 };
public static byte[] EEPROM = new byte[] { 0x42, 0x4d, 0x47, 0x4a, 0x45, 0x54, 0x20, 0x32, 0x30, 0x32, 0x30 };
static bool LoadBin()
//Loads bin that was dragged onto application.
try
byte[] file = System.IO.File.ReadAllBytes(BinFile);
if (file.Length == 32768L)
Bin = new byte[32768]; //Sets byte array size 32K
Bin = file;
Console.WriteLine("Loaded 32K");
return true;
else if (file.Length == 65536L)
Bin = new byte[65536]; //Sets byte array size 64K
Bin = file;
Console.WriteLine("Loaded 64K");
return true;
return false; //Unsupported size fail.
catch
return false; //Something had issue fail.
public static void SetNoDelay() //Disables delay that emulates bluetooth speed.
NoDelay = !NoDelay;
Console.WriteLine("No Delay Mode: "+ NoDelay);
static byte Setup()
//Define what protocol to use.
int P = 0;
Console.WriteLine("\nWhat Protocol To Emulate: \n(1) Moates Ostrich 1.0\n(2) Moates Ostrich 2.0\n(3) CobraRTP\n(4) ECUTamer\n(0) Moates Demon(WIP)" + FS);
FS = "";
int.TryParse(Console.ReadLine(), out P);
switch (P) //Switch version array for what emulator your using.
case 0:
Console.WriteLine("Protocol: Moates Demon");
Version = new byte[] { 0x01, 0x09, 0x44 };
break;
case 1:
Console.WriteLine("Protocol: Moates Ostrich 1.0");
Version = new byte[] { 0x10, 0x07, 0x4F };
break;
case 2:
Console.WriteLine("Protocol: Moates Ostrich 2.0");
Version = new byte[] { 0x14, 0x09, 0x4F };
break;
case 3:
Console.WriteLine("Protocol: CobraRTP");
Version = new byte[] { 0x14, 0x18, 0x43 };
break;
default:
Console.WriteLine("Protocol: ECUTamer");
Version = new byte[] { 0x01, 0x28, 0x4F };
break;
try
Console.WriteLine("\nSelect Port:");
//Builds list of avaliable COMPorts
foreach (string s in SerialPort.GetPortNames())
Console.WriteLine(s);
catch { Console.WriteLine("No Avaliable ComPorts"); }
//Read back COMPORT selection.
bool NC = true;
while (NC)
string CP = Console.ReadLine().ToUpper();
if (CP.Contains("COM"))
serialPort_0 = new SerialPort();
//Setup Baud rate
Console.WriteLine("\nWhat Baud Rate:\n(1) 115.2K\n(2) 921.6K");
int B = 1;
int.TryParse(Console.ReadLine(), out B);
if (B == 2)
serialPort_0.BaudRate = 921600;
else
serialPort_0.BaudRate = 115200;
serialPort_0.ReadBufferSize = 64000;
serialPort_0.PortName = CP;
serialPort_0.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler);
NC = false;
else
Console.WriteLine("Must Use Format COM# (#=number)");
return (byte)P; //Returns protocol selection.
static bool MakeBin()
BinFile = Directory.GetCurrentDirectory() + "\\EMUSIM.bin";
if (File.Exists(BinFile)) //Checks if old file already exsists.
Console.WriteLine("Found a exsisting bin file:\n" + BinFile);
if (!LoadBin()) //Trys to load the file.
return false;
else
return true;
else
//Makes a Bin File if one not opened.
int P;
Console.WriteLine("No Bin Loaded\nCreating Blank ECUSIM.bin\nWhat Chip Size Fo You Want To Emulate\n(1) 32KB\n(2) 64KB" + FS);
FS = "";
switch (P)
case 2:
Console.WriteLine("Creating 64KB");
break;
default:
Console.WriteLine("Creating 32KB");
break;
try
File.WriteAllBytes(BinFile, Bin);
return true;
catch
Console.WriteLine("Failed to create temp file EMUSIM.bin");
return false;
public static void SaveFile()
//Saves file to opened file or blank file.
try
System.IO.File.WriteAllBytes(BinFile, Bin);
Console.WriteLine("Saved Bytes To Bin: " + BinFile);
catch
Console.WriteLine("Failed To Saved Bytes To Bin: " + BinFile);
//Erases byte array memory.
public static void ClearFile()
Array.Clear(Bin, 0, Bin.Length);
Console.WriteLine("Zeroed Bin Memory.");
//Help prompts
public static void HELP()
string HelpHeader = @"
╚═╝ ╚═╝╚══════╝╚══════╝╚═╝" + "\n";
string keys = "ESC = Exit Program\nSpace = Save Memory to File\nBackspace = Clear Memory\nF1 = Toggle Bluetooth Delay";
ConsoleKey H = Console.ReadKey().Key;
switch (H)
case ConsoleKey.Escape:
Environment.Exit(0);
break;
case ConsoleKey.Spacebar:
SaveFile();
break;
case ConsoleKey.Backspace:
ClearFile();
break;
case ConsoleKey.F1:
SetNoDelay();
break;
default:
Console.WriteLine(HelpHeader + Encoding.ASCII.GetString(EEPROM) + HS + keys);
break;
public static void DataReceivedHandler(object sender, SerialDataReceivedEventArgs e)
//Handles Incoming data.
SerialPort sp = (SerialPort)sender;
if (!NoDelay)
Thread.Sleep(TimeOut);// Delay to allow bluetooth buffer to fill before reading.
else
Thread.Sleep(20);// Delay 20ms to reduce cpu load.
byte[] inputbytes = new byte[sp.BytesToRead];
sp.Read(inputbytes, 0, inputbytes.Length);
if (inputbytes.Length != 0)
if (Protocol == 0) //Trys parse the Demon protocol
if (!DemonAPI(inputbytes, sp))
ErrorLog(Encoding.Default.GetString(inputbytes));
else
if (!OstrichAPI(inputbytes, sp)) //Trys parse the Ostrich protocol
private static void ErrorLog(string Debug)
if (Debug.Length > 16)
Debug = Debug.Substring(0, 16); //limited to 16 char
Console.Write("SD: " + Debug); //Dump string that failed
//Handles outgoing data
public static void DataSender(byte[] DataByte, SerialPort sp)
if (sp.IsOpen)
sp.Write(DataByte, 0, DataByte.Length);
static void Main(string[] args)
//Code starts here
Console.WriteLine(Header);
//Checks if file has been dragged onto application.
if (args.Length > 0 && File.Exists(args[0]))
BinFile = args[0];
Console.WriteLine("Loading Bin:" + BinFile);
Console.WriteLine("Failed to load to byte array.");
if (!MakeBin()) //Trys to make new temp file.
Console.WriteLine("Complete Fail, Will close.");
Console.ReadKey();
else
Console.ReadKey();
Protocol = Setup(); //Sets up Protocol
serialPort_0.Open(); //Open COMPort
if (serialPort_0.IsOpen)
Console.WriteLine(@"
Press Enter Key To See Command List.
else
Press Any Key To Close!
Console.ReadKey();
while (true)
HELP();
public static bool DemonAPI(byte[] bytearray, SerialPort sp)
if (VersionRequested(bytearray, sp)) //Version request VV
{ return true; }
if (EnableOnboard(bytearray, sp)) //Enable onboard datalogging.
{ return true; }
if (!StandardCheckSum(bytearray)) //Checksum
{ return false; }
if (SlowRead(bytearray, sp)) //Read bin bytes slow
TimeOut = 60;
return true;
if (SlowWrite(bytearray, sp)) //Write bin bytes slow
TimeOut = 120;
return true;
if (FastRead(bytearray, sp)) //Read bin bytes Fast
TimeOut = 60;
return true;
if (FastWrite(bytearray, sp)) //Write bin bytes Fast
TimeOut = 600;
return true;
if (SerialRequest(bytearray, sp)) //Serial number request
{ return true; }
if (QCSRequest(bytearray, sp)) //Quick CheckSum request BMGJET Protocol
{ return true; }
if (EEPROMRequest(bytearray, sp)) //EEPROM Information requested
{ return true; }
if (EEPROMRequest2(bytearray, sp)) //EEPROM Information requested
{ return true; }
if (BankActive(bytearray, sp)) //Select Active Emulation Bank.
{ return true; }
if (BankStatic(bytearray, sp)) //Select Static Emulation Bank.
{ return true; }
return false; //No valid commands found.
public static bool OstrichAPI(byte[] bytearray, SerialPort sp)
if(VersionRequested(bytearray, sp)) //Version request VV
{return true;}
{return false;}
TimeOut = 60;
return true;
TimeOut = 120;
return true;
TimeOut = 60;
return true;
TimeOut = 600;
return true;
{return true;}
{ return true; }
{ return true; }
{ return true; }
{ return true; }
{ return true; }
public static bool VersionRequested(byte[] bytearray, SerialPort sp)
//VV request
if (bytearray[0] == 0x56 && bytearray[1] == 0x56)
TimeOut = 600;
Console.WriteLine("Version Requested.");
DataSender(Version, sp);
return true;
return false;
public static bool BankStatic(byte[] bytearray, SerialPort sp)
//Get Static Emulation Bank
//42 45 53 DA write
//oo read
if (bytearray[0] == 0x42 && bytearray[1] == 0x45 && bytearray[2] == 0x53 && bytearray[3] == 0xDA)
Console.WriteLine("Static Bank Info Requested");
byte[] BANKINFO = new byte[] { 0x00 };
DataSender(BANKINFO, sp);
return true;
return false;
public static bool BankActive(byte[] bytearray, SerialPort sp)
//Get Active Emulation Bank Succeeded: Bank 0
//42 52 52 Bank write
//00 read
if (bytearray[0] == 0x42 && bytearray[1] == 0x52)
Console.WriteLine("Active Bank Info Requested");
return true;
if (bytearray[0] == 0x42 && bytearray[1] == 0x53)
DataSender(OK, sp);
return true;
return false;
public static bool EEPROMRequest(byte[] bytearray, SerialPort sp)
if (bytearray[0] == 0x45 && bytearray[1] == 0x07 && bytearray[3] == 0x01)
Console.WriteLine("EEPROM Info Requested");
byte[] EEPROMINFO = new byte[] { 0x50, 0x02, 0x00, 0x55, 0x02, 0x01, 0x10 };
DataSender(EEPROMINFO, sp);
return true;
return false;
public static bool EEPROMRequest2(byte[] bytearray, SerialPort sp)
if (bytearray[0] == 0x48 && bytearray[1] == 0x52 && bytearray[2] == 0x07 && bytearray[4] == 0x01 && bytearray[5] == 0xA2)
if (Protocol == 0)
EEPROMINFO[0] = 0x44;
return true;
return false;
public static bool SerialRequest(byte[] bytearray, SerialPort sp)
if (bytearray[0] == 0x4E && bytearray[1] == 0x53)
Console.WriteLine("Serial Number Requested");
DataSender(Serial, sp);
return true;
return false;
public static bool StandardCheckSum(byte[] bytearray)
//Checksum used on most packets.
byte Tchecksum = 0;
int bytelen = bytearray.Length;
byte Cchecksum = bytearray[bytelen - 1];
//Calculate checksum
for (int i = 0; i <= bytelen - 2; i++)
Tchecksum += bytearray[i];
//Check valid checksum.
if (Tchecksum != Cchecksum)
Console.WriteLine("CheckSum Failed");
return false; //Not valid stop processing
return true;
//Fast Write
public static void BinFastWrite(byte[] bytearray, SerialPort sp)
int BlockSize = (256 * (bytearray[2]));
if (bytearray.Length == BlockSize + 6) //normal
int Address = GetAddress(bytearray[3], bytearray[4]);
//Pack bin with write bytes.
for (int i = 0; i < BlockSize; i++)
Bin[Address + i] = bytearray[i + 5];
Console.WriteLine(BlockSize + " Bytes written to " + Address);
DataSender(OK, sp);
else if (bytearray.Length == BlockSize + 8) //encrypt byte 3/4 random encrypt bytes
//Removed function to protect intellectual property
Console.WriteLine("Encrypted fast write transfere");
DataSender(OK, sp);
//Slow Write
public static void BinWrite(byte[] bytearray, SerialPort sp)
int BlockSize = GetBlockSize(bytearray[1]);
if (bytearray.Length == BlockSize + 5)
int Address = GetAddress(bytearray[3], bytearray[2]);
Bin[Address + i] = bytearray[i + 4];
DataSender(OK, sp);
else if (bytearray.Length == 8) //encrypted slow write
Console.WriteLine("Encrypted slow write transfere");
DataSender(OK, sp);
//Slow Read
public static void BinRead(byte[] bytearray, SerialPort sp)
if (bytearray.Length == 6) //normal
//Setup buffer
byte[] Binbuff = new byte[BlockSize];
//Pack the buffer
for (int i = 0; i <= BlockSize - 1; i++)
Binbuff[i] = Bin[Address + i];
//Output buffer.
Console.WriteLine(BlockSize + " Bytes read from " + Address);
DataSender(checksum(Binbuff), sp);
else if (bytearray.Length == 8) //encrypted fast read
Console.WriteLine("Encrypted slow read transfere");
DataSender(OK, sp);
//Fast read
public static void BinFastRead(byte[] bytearray, SerialPort sp)
if (bytearray.Length == 5) //fast read
//Setup buffer
//Pack the buffer
//Output buffer.
Console.WriteLine("Encrypted fast read transfere");
DataSender(OK, sp);
//Block size correction.
public static int GetBlockSize(int BlockSize)
if (BlockSize == 0)
BlockSize = 256;
return BlockSize;
//Get byte array address
public static int GetAddress(int MSB, int LSB)
int Address = (MSB | LSB << 8);
if (Address >= Bin.Length)
Address -= 32768; //Resize 64K back to 32K.
return Address;
//Calculate Checksum and create new byte array with it added on.
public static byte[] checksum(byte[] bArray)
byte cs = 0;
foreach (byte raw in bArray)
cs += raw;
byte[] newArray = new byte[bArray.Length + 1];
bArray.CopyTo(newArray, 0);
newArray[newArray.Length - 1] = cs;
return newArray;
public static bool SlowRead(byte[] bytearray, SerialPort sp)
if (bytearray[0] == 0x52 && bytearray.Length == 5) //R
BinRead(bytearray, sp);
return true;
return false;
public static bool SlowWrite(byte[] bytearray, SerialPort sp) //W
if (bytearray[0] == 0x57)
BinWrite(bytearray, sp);
return true;
return false;
public static bool FastRead(byte[] bytearray, SerialPort sp) //ZR
if (bytearray[0] == 0x5A && bytearray[1] == 0x52)
BinFastRead(bytearray, sp);
return true;
return false;
public static bool FastWrite(byte[] bytearray, SerialPort sp) //ZW
if (bytearray[0] == 0x5A && bytearray[1] == 0x57)
BinFastWrite(bytearray, sp);
return true;
return false;
public static bool EnableOnboard(byte[] bytearray, SerialPort sp) //DOLY Enable onboard
if (bytearray[0] == 0x44 && bytearray[1] == 0x4F && bytearray[2] == 0x4C && bytearray[3] == 0x59)
DataSender(OK, sp);
return true;
if (bytearray[0] == 0x44 && bytearray[1] == 0x4F && bytearray[2] == 0x4C && bytearray[3] == 0x79)
DataSender(OK, sp);
return true;
return false;
//Quick Check Sum
//5a 43 53 PacketCS write
//MemoryCS read
public static bool QCSRequest(byte[] bytearray, SerialPort sp)
if (bytearray[0] == 0x5A && bytearray[1] == 0x43 && bytearray[2] == 0x53)
QuckCS(sp);
return true;
return false;
public static void QuckCS(SerialPort sp)
//Sum of Emulator Memory.
byte[] QCS = new byte[1];
foreach (byte B in Bin)
QCS[0] += B;
Console.WriteLine("Quick CheckSum: " + QCS[0].ToString("X2"));
DataSender(QCS, sp);
using System.IO;
using System.Text;
class Program
try
Bin = file;
return true;
Bin = file;
return true;
catch
NoDelay = !NoDelay;
static byte Setup()
int P = 0;
FS = "";
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
break;
try
bool NC = true;
while (NC)
//Setup Baud rate
int B = 1;
if (B == 2)
else
NC = false;
else
return false;
else
return true;
else
int P;
FS = "";
switch (P)
case 2:
break;
default:
break;
try
return true;
catch
return false;
try
catch
//Help prompts
switch (H)
break;
SaveFile();
break;
ClearFile();
break;
case ConsoleKey.F1:
SetNoDelay();
break;
default:
break;
if (!NoDelay)
else
else
if (sp.IsOpen)
//Code starts here
BinFile = args[0];
Console.ReadKey();
else
Console.ReadKey();
else
Console.ReadKey();
while (true)
HELP();
{ return true; }
{ return true; }
{ return false; }
TimeOut = 60;
return true;
TimeOut = 120;
return true;
TimeOut = 60;
return true;
TimeOut = 600;
return true;
{ return true; }
{ return true; }
{ return true; }
{ return true; }
{ return true; }
{ return true; }
{return true;}
{return false;}
TimeOut = 60;
return true;
TimeOut = 120;
return true;
TimeOut = 60;
return true;
TimeOut = 600;
return true;
{return true;}
{ return true; }
{ return true; }
{ return true; }
{ return true; }
{ return true; }
//VV request
TimeOut = 600;
return true;
return false;
//42 45 53 DA write
//oo read
return true;
return false;
//00 read
return true;
DataSender(OK, sp);
return true;
return false;
return true;
return false;
if (Protocol == 0)
return true;
return false;
return true;
return false;
byte Tchecksum = 0;
return true;
//Fast Write
DataSender(OK, sp);
DataSender(OK, sp);
//Slow Write
DataSender(OK, sp);
DataSender(OK, sp);
//Slow Read
//Setup buffer
//Pack the buffer
//Output buffer.
DataSender(OK, sp);
//Fast read
//Setup buffer
//Pack the buffer
//Output buffer.
DataSender(OK, sp);
if (BlockSize == 0)
BlockSize = 256;
return BlockSize;
return Address;
byte cs = 0;
cs += raw;
return newArray;
return true;
return false;
return true;
return false;
return true;
return false;
return true;
return false;
DataSender(OK, sp);
return true;
DataSender(OK, sp);
return true;
return false;
//Quick Check Sum
//MemoryCS read
QuckCS(sp);
return true;
return false;
QCS[0] += B;
