Loads of parts for chipping obd1 ECU's - look inside
HybridEj1
#1 ◈ 2025-01-15
I recently cleaned out my garage and this is what I found. I have not worked on any honda ECU since around 2012 and I must have forgotten I had all this.
Please email me directly. I don't visit the board often and email is the fastest response. - itworksagain@gmail.com
Please have a look at all the photos. I would prefer to sell this all in one shot, but if I need to break apart the chips from the ecu's, so be it.
I'm not going to separate the SST's from everything else, sorry.
There are:
NEW:
65x SST 512KB - 28pin EEPROM
83x ST M74HC373 - 20pin through hole
98x ST 74HC373 - 20pin surface mount
30x unknown brand - 74HC373 - 20 pin surface mount
138 Tyco 28pin LIF sockets
38x 28pin ZIF sockets
122x on/off 2 pin through hole switch
MISC stuff:
OBD2-1 harness adapter wires
Screws galore
Extra electronic parts pulled from old ECU's and stored for later use - Such as 5050's and 5151's, caps, resistors, diodes, etc...
Some NEW power caps
Some OBD0 and OBD1 header plugs
ECUS:
2x P28 (real) that do not energize the fuel pump
3x P05/06 conversions that do not energize the fuel pump
1x stock P75
1x P75 converted to P72 without knock sensor
1x PR3 - real and unknown if it works
Other MISC ecus as shown - P08, P84, P2E
https://photos.app.goo.gl/gun9H6QiKdpqf5Aa7
