H1C1 and H1C2 Vertical Sub-Boards
7rrivera7
#1 ◈ 2021-05-18
Has anyone been able to troublehoot these and fix them? I have a good collection of bad boards with ignition codes and would like to repair them.
7rrivera7
#2 ◈ 2021-05-18
Re: H1C1 and H1C2 Vertical Sub-Boards
18 views and no response? What happened to the great contributors that were on this forum?
majdi
#3 ◈ 2021-05-18
Simply connect all supply and ground pinout.. Inject 5-12v pwm signal to pin ckp, cyp and tdc. Then just test with oscilloscope the output signal. Common problem is the ic problem or any short or open circuit.
viewtopic.php?t=23592
bmgjet
#4 ◈ 2021-05-18
Theres a aftermarket board you can replace it with that Honda Rulez made.
7rrivera7
#5 ◈ 2021-05-18
Are you sure it replaces H1C1 & H1C2?
I know there is a Coil on Plug board which I sell and it looks similar but I have not seen a product that replaces these boards.
shiftyjonno
#6 ◈ 2021-05-18
I hope these help
projectteg
#7 ◈ 2021-05-18
Would these boards throw a icm signal loss code?
shiftyjonno
#8 ◈ 2021-05-18
Most definitely will be part of it.
crisaguilar
#9 ◈ 2021-05-18
I repair a lot of them major times the problem are the op amp but I find some problems with caps too.
The right way to test is with a oscilloscope
7rrivera7
#10 ◈ 2021-05-18
How would a person just starting with an oscilloscope troubleshoot these boards?
