joeydgaf4200
#1 ◈ 2026-03-13
[*] do you have a base map for a d15 block with a d16 head throttle body and intake manifold with a turbocharger 370cc injectors 5 lb spring in the wastegate high flow pressure fuel pump .... I'm just trying to avoid ignition a timing problems on my air fuel ratio I pretty much have an okay base map but I need ignition timing l
