P28 with Snake EMU need help
dleal50
#1 ◈ 2026-03-08
Anybody have experience installing the most recent snake EMU on a P28 can offer help? Using HTS latest "snake" edition, I'm not able to connect with the snake option. It will connect in demon mode how ever when I update anything it seems like the ECU is not taking it. My rev limit is stuck at 4k, and I've verified I do not have the launch control or rev limit set to 4k. The car does run how ever but not well. I've also tried using the utility you can get from the snake emu download to flash a rom onto it but that doesnt seem to take either and my rev is still limited to 4k. I'm just not sure what part i'm messing up here, if its the tune file i'm making (I dont think its this) or maybe I messed something up installing the emu? (all the soldier joints appear fine) I'm just not sure how to troubleshoot this at this point if anybody can offer help I would appreciate it. Thank you.
majdi
#2 ◈ 2026-03-08
Re: P28 with Snake EMU need help
should pm armando at facebook, he will guide about installation more... if you used lates version snake v2.1, maybe the problem is connection with ecu. SnakeEmu used round pin. It easy get loose or not contact. What i do, used normal wide ic base 28pin. and for cn2, also used ic base that u cut it off and only use 3 pin. Normal ic base dont used round pin, just use square pin one
