Hi
im lookin for d14a4 base map, or any other D14 map. Does anybody have one? I have P06 ECU.
Thanks in advance.
Re: D14A4 BASE MAP
Stock d14a2 (Ecu=p1j)
Re: D14A4 BASE MAP
Cheers, is there any major difference between d14a4 and d14a2? I have '96 civic EJ9. iirc d14a2 is for MB/MJ?
Re: D14A4 BASE MAP
https://en.wikipedia.org/wiki/Honda_D_engineGoogle says:
The Honda D14A2 is an OBD-1 engine with VTEC technology producing 89 hp and 117 Nm of torque, while the D14A4 is a non-VTEC, OBD-2 engine with a lower compression ratio and 74-75 hp, You can use base map for D14A2, just disable VTEC and VTEC error.
