Does PGMFI have any of these for sale? I am trying to convert a P06, I'd like 5 or so of each...TIA
1N4001 is a radioshack part.. You can get it virtually anywhere. Standard diode
Thanks, so all I will need to locate then is the 5151's. i just figured that I would try to purchase from PGMFI in an attempt to donate some to the cause...
We've talked about getting an order of 5151s, but it's kinda expensive. I'm sure there will be plenty of interest if we can get it together...
Sounds good. I will be interested, if there is a new order that gets placed I'll probably even buy 20 or 30 just to ensure that I have some ........
Depending upon cost, I'd be in for 10 or so. Course, would this be for the equivalent that Digikey has? How many would we need for a better price? 50?
500 minimum for the true-blue Allegro/Sanken SI-5151SG (which replaced the Sanken SK-5151 used in our ECUs)
If you're looking for SK-5151, just use a IR6220..
Please see
viewtopic.php?t=181&highlight=sk5151 first for specific install instructions..
sk 5151 or equiv
Re: sk 5151 or equiv
joshuavillasenor wrote:
I know this is an old old old topic but i am INTERESTED in the 5151's.
What's the break down on the "amount purchase" and "price" on that?
I tried searching part # IR-6220 but nothing came up on Digikey or Allegro.
Let me know...
Thanks!
Re: SK-5151S & 1n4001?
Most members in this thread no longer have active accounts, so not likely to get a response, plus since then, they have discountinued 5151s I believe, so you will have to order them from someone who has a stock. I believe Xenocron and Moates do, Smooth1 (hrtuning) might have them as well.
I have over 700 hundred sk5151s. If interested contact me via message
